New & Questions
Old Sep 25, 2010 | 03:11 PM
TechGreek's Avatar
TechGreek
Talking New & Questions
Hey Guys,
This isn't my first Lexus (well personally it is, my boss has owned a few 400's) but I just picked up a SC300 from JDM Lexey this weekend.
It has coil overs, it's been dropped, etc, etc.
My question is going down the interstate, it sounds like there is a thumping noise from the front left wheel. The Upper and Lower Control arm are good. I've also got an issue where the steering sometime likes to "wiggle".
The first thing I thought were tie rods, UCA, etc but they all look ok. The steering rack has been covered in PS fluid for a while now so I'm guessing the bushings are worn out.
Do you think this could be the culprit?
Thanks
Tech
Old Sep 25, 2010 | 03:24 PM
good2go's Avatar
good2go
Yes.
btw, you can usually see that the steering rack bushings are shot if you get down and look at them.
Also search here for tightening front subframe assembly and sway bar end link issues.
Old Sep 25, 2010 | 03:59 PM
TechGreek's Avatar
TechGreek
The car is so low that I can't fit my regular jack under it so I'm waiting on a new low profile to come in.
Old Sep 25, 2010 | 05:58 PM
1WILLY1's Avatar
1WILLY1
Is this thumping regular--repetative-------are you sure you dont have a bulge in your tire------I have one in mine right now and it thumps while on the highway.
Old Sep 25, 2010 | 08:25 PM
TechGreek's Avatar
TechGreek
I would almost say that considering he put used tires on the front but if I turn them ever so slightly to the left or right (I'm talking a 1/4 inch turn increment) then it goes away but will come back whenever it straightens back out.
It's only at high speeds I've discovered tonight.
Old Sep 26, 2010 | 08:44 AM
1WILLY1's Avatar
1WILLY1
Yes you may have a small bulge that isnt noticed as much when the wheel is turned slightly----------you really only notice these problems at high speeds---------regular crousing in the city u wouldnt notice a thing really---unles it was a big bulge.
By the way everyone ----NEVER BUY NANKANGS----total garbage.
Old Sep 26, 2010 | 03:28 PM
TechGreek's Avatar
TechGreek
I was going to get it up today and look at it but decided to say screw it and here's why.
I went to replace my spark plugs and spark plug wires (it didn't have a miss before hand except every so often but it did have wires starting to shred).
I pull the throttle body back, remove the coolant line, no big deal. An hour tops to replace the wires and plugs.
First mistake, pull the wires and not mark them off the dizzy cap. I don't know what I was thinking.
I put everything in, NGK IRX Plugs, "Xact OEM Wires", and had a miss. Well I obviously had the connections wrong. Fixed that and still a miss.
I pulled the throttle body and found #4 loose and not clicked down all the way. Put everything back together. Same thing...at this point I'm irritated and have the flu.
Pull everything BACK apart, and check all the wires, it's fine. Pulled the plugs, re-gapped them and put it back together. Still missing.
FML at this point, pull everything BACK apart and put the denso's back in that were already in there and putted up to the store with a miss.
Get some Denso Platinum plugs thinking maybe something was wrong, go to take it off again but this time I double checked the ONE connection I didn't check. The ignition coil to dizzy cap. Apparently even though it clicked the metal prong didn't make it's way in there all the way.
Yes, so I said screw detailing it today and screw looking at the subframe. I'll put the NGK's back in next weekend. I'm about to pound some Theraflu + Water down and pass out.
Stroock639
Jan 31, 2020 07:40 PM
Moarpower
Dec 17, 2018 09:26 AM
BoostAddct
Oct 28, 2011 09:29 PM
rwdanthony
SC400 / 300 Classifieds
21
Sep 21, 2011 10:38 PM
TomLee
Apr 3, 2010 04:04 PM
