My evaluation of Tanabe GF210 MKI4 lowering springs.
Every review should be done something like this. Now that this thread is bumped how is the ride now? and do you have any more pics? 1st pic looks to be on a incline.
you should pair the supra springs with supra shocks. springs are similar dimension wise but different enough that you cannot use the supra spring on the SC shocks. If you try it will only work for the rear (or was it front) but not both there is a different in the mounts. Its best to just get supra shocks when using supra springs and SC shocks when using SC springs.
I have the SC nf210's and the ride is great but the drop could be a little lower. these look like a better solution if you are getting shocks anyways then you can get supra ones and use these.
Ok first off great review. I rarely have to start a thread because there is ALWAYS one out there dealing with exactly my question/dilemma/comment/concern you just have to use that search button...(hint hint) then maybe I would stop seeing new ppl like myself catching grief all the time for being lazy...anyway I have a chance to buy a pair of said springs for 125 off Craigslist my concern is that the guy/girl says they cut 1 coil off the front springs to make them .5 lower. I just want to check on this b4 I buy them if it will be ok. Here is pic of said Ad...
[QUOTE=Ali SC3;8615031]you should pair the supra springs with supra shocks. springs are similar dimension wise but different enough that you cannot use the supra spring on the SC shocks. If you try it will only work for the rear (or was it front) but not both there is a different in the mounts. Its best to just get supra shocks when using supra springs and SC shocks when using SC springs.
Ali SC:
Just wondering about this whole Supra vs SC mount style and why Supra GF210 springs can't be paired with SC shocks, if my memory tells me correct Supra shocks are mounted/bolted differently from the SC, and there for cannot be used on SCs period, feel free to correct of me or send a link to another thread that talks about this stuff, please do elaborate on the difference if at all possible!?
Ali SC:
[QUOTE=RUSSIAN300;10237983]
MKIV Supra shocks work just fine on the SC. My coil overs were for the Supra, but work perfectly on my SC.
Ali SC:
Ali SC:
From what I remember the spring perches sit at different levels between the Supra and Soarer/SC, hence why the rear springs are incompatible between the two (Soarer/SC shock and Supra spring, or vice versa).
The strut mounting points are identical between the two so the Supra and Soarer/SC struts are interchangeable as a whole unit.
hambone525
Dec 21, 2013 04:51 PM
AristoGW
Oct 3, 2005 08:15 PM
