Installing IMF headers SC400
Old Sep 21, 2010 | 03:01 PM
gstracer's Avatar
gstracer
what kind of power gain is expected with these headers by the way?
Old Sep 21, 2010 | 03:55 PM
masagsxr's Avatar
masagsxr
Very cool.... Wow, a short 14mm huh... I don't think I have one of those sucker. Will there be room for an air ratchet?
Old Sep 21, 2010 | 03:56 PM
mtnrat's Avatar
mtnrat
I had an air ratchet and could only get to a couple of nuts.
Old Sep 22, 2010 | 11:38 AM
Boergy's Avatar
Boergy
Thanks for the informations!
i will install my headers in the spring, good to have any information!
greets
Tom from Austria
mtnrat's Avatar
mtnrat
Had a look at my hands today. Looks like I had fight with a cat.
Old Sep 22, 2010 | 11:19 PM
LEXXIUM's Avatar
LEXXIUM
Great job man! Hard work pays off, are you doing custom exhaust with high flow cats or using the stock one?
Old Sep 23, 2010 | 07:17 AM
mtnrat's Avatar
mtnrat
I am going to use the stock one for now. As far as I can see I only had two cats which are now gone. The "centre cat" in the Canadian version is not a cat as the US version with the sub-cat which is US spec only.
Old Sep 28, 2010 | 05:30 PM
mtnrat's Avatar
mtnrat
Found out that the transmission won't fit between the headers for installation. I had to loosen the passenger side, install the tranny, and then retighten the header. Not too bad as the passenger side has the most room. Will find out how the exhaust fits very soon. Everything has clearance so far.
Old Sep 28, 2010 | 08:22 PM
mtnrat's Avatar
mtnrat
Got everything hooked up... That I can. The drivers side header and exhaust do not line up, so it is off to the shop for some welding, to make everything fit right.
Old Sep 29, 2010 | 09:37 AM
Boergy's Avatar
Boergy
Hello!
which gasket you are used between the header and the original pipe?
Thanks
Tom
Old Sep 29, 2010 | 12:19 PM
mtnrat's Avatar
mtnrat
I am using an aftermarket ring gasket, similar to the factory metal ring gasket.
Old Sep 29, 2010 | 03:10 PM
1uzDreamSC's Avatar
1uzDreamSC
so you still havent driven it yet?
hurry up lol
Old Sep 30, 2010 | 08:01 AM
mtnrat's Avatar
mtnrat
hurry up lol
LOL, I live in a one horse town with basically only two mechanic shops and both are pretty busy. I don't weld so it is at the shop waiting. I did drive it the short distance to the shop. Based on that, the sound is reminiscent of a ZZ Top concert I went to in the late seventies.
Old Oct 1, 2010 | 06:19 PM
mtnrat's Avatar
mtnrat
Picked up the car. I am still using the stock exhaust so the sound is just a little more throaty. I will have to have someone else do a drive by in it to see what it sounds like. There is no check engine light but I have only driven it six miles.
Old Oct 1, 2010 | 07:06 PM
Photon440's Avatar
Photon440
Throaty. Check.
No CEL. Check.
But does it feel more powerful to you?
-=Photon=-
