SC300 convert Auto to Manual.. Need help.
Thats something you shouldn't ask on here... Everyone will just tell you to search.
Anyways..., this should be everything needed.
Clutch lines
CMC
Clutch Slave
Cutch pedal and brake pedal accembly (Or you can cut the brake pedal in half to save money)
Drive shaft
MT Tranny bracket with mount
5-speed shift boot with plastic surrounding
You can get everything you need from driftmotion.com. I just bought all of that plus more from them, great people to work with...
http://store.driftmotion.com/static/...00pedalset.php
http://store.driftmotion.com/static/...hifterboot.php
Also depending on what tranny you use you might need different parts... If using the R154 you need the front half of a Turbo MK3 supra drivshaft and stock SC rear half. Shifter will also need to be extended about 3" to fit the shifter hole.
If you use the W58 it should just be a plug in play install if you have all the right parts...
there might be a few other small things im missing, if so someone please finish the list for me!
Clutch lines
CMC
Clutch Slave
Drive shaft
