Painting LS400 Caliper & Logo Process..
Originally Posted by 2BENVD
"I went ahead and painted the calipers red with the "LEXUS" logo in black. The logo has been painted on... Not a sticker...I can tell you the simple process if you want it"
would like to know how you did it, btw yours turned out wonderful, also can you tell me exactly which set you went and bought on brakeperformance.com, the break upgrade is only for the front of the car right? thanks in advance
Here are the "tools/procedure" that you'll need:
1. A pack of "packing slip paper" from Walmart. Its a sheet of paper that has an adhesive back. Its basically a blank sticker the size of a sheet of paper.
2. A x-acto knife from Walmart or your local hobby shop.
3. Go to BRANDSOFTHEWORLD.COM and type in Lexus in the search field. Print the logo that you desire on the packing slip paper.
4. Buy 2 cans of caliper paint. 1 for the color of the logo. And the other for the overall color of the caliper.
5. Use the x-acto knife to cut out the logo- (take your time and be very precise.)
6. Make sure that your caliper is clean of all oils. Use brake parts cleaner to clean it up real nice.
7. Spray the whole caliper the color that you want the logo to be. You have to spray the whole caliper because you want it to have an even tone once your done. Let dry.
8. Once dried, peel the backing off the logo and stick it on the caliper.....
9. Spray the caliper with the other color and let dry. (I used 2 coats ). Make sure that its completely dried...
10. Slowly remove the logo and there you have it! Your custom "painted" rotors...
Let me know if you have any questions...
I bought the slotted and drilled set with black zinc coating on it. You'll be amazed once you get them.. A black rotor? Its SICK!!!!
Painted caliper with painted logo:
Bootyman
SC- 1st Gen (1992-2000)
07-15-17 06:59 PM
BigBang
Suspension and Brakes
02-23-16 05:43 AM
CAN-Vancouver Sage Front RCA 30mm & 18mm
Sonic_RC
12-17-11 11:37 PM
dwebb99
04-15-09 03:54 PM
