washer fluid doesnt spray help..
Old Aug 6, 2010 | 08:33 PM
tuterz's Avatar
tuterz
Default washer fluid doesnt spray help..
i was wondering if any of you guys had a problem with you washer fluid not spraying anymore.. after i got my car back from the paint shop i tried to use my washer fluid i didnt get anything to spray. i thought it was empty so i bought more fluid ,, filled it up .. still doesnt spray.. i thought the holes were plugged so i used a needle to poke it clear.. still doesnt spray.. is there a fuse or anything that could have went bad? how would i check it if there was..
Old Aug 6, 2010 | 08:46 PM
SChema's Avatar
SChema
Do you hear the washer motor whine when you press the spray?
Old Aug 6, 2010 | 08:48 PM
good2go's Avatar
good2go
First off, can you hear the pump working when you try and spray the windows?? Try having someone operate it for you while you listen at the either the fill spout or down in fender well in front of the driver side wheel. If it's operating, then maybe you could look for a disconnected water line. There are connections which could be loose/disconnected at the pump, around the driver side hood hinge, and again on the under side of hood itself.
If the pump isn't running, it could have died, or power was unplugged, or the fuse could be bad.
Old Aug 7, 2010 | 11:06 AM
tuterz's Avatar
tuterz
thank you guys.. ill try to listen to it when i have a chance..
Old Aug 7, 2010 | 01:56 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If the motor and lines are hooked up and working, the lines may be clogged. Take a air line and spray ever so gently, into the line, and see if that doesnt free up the obstruction. Mine was and after doing this it works great again. Just a thought.
MidniteGX
GX - 1st Gen (2003-2009)
Mar 17, 2014 09:16 PM
thegov3
Dec 24, 2013 11:11 AM
Muti007
Jan 17, 2012 06:55 AM
