r-154 soarer tranny problems
Old Aug 4, 2010 | 01:42 PM
rfinnie91's Avatar
rfinnie91
Default r-154 soarer tranny problems
so i got a sc300 with a 2jzgte in it with the r154 soarer transmission... when just starting to go it makes like a squealing noise and some times shutters quite hard.. any help will help thanks.. the transmission fluid is good. what could it be?
Old Aug 4, 2010 | 02:41 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
maybe a little more info, is this a new motor/tranny setup, just the tranny? stock diff?
clutch/PP combo?
sounds like the break in period on my act 6 puck sprung clutch kit with the extreme PP on my w58.
It sounds like a "wwweeeeeeeeeeeeeee thud thud thud" and then "bam" you are in gear.
The wee went away for the most part after break in and the shuddering when I got new motor mounts. the open diff can also shudder, for me its from a stop when I give it too much gas without spinning tires, the insides of the diff just go crazy for a second.
Old Aug 4, 2010 | 02:46 PM
rfinnie91's Avatar
rfinnie91
yeah its a new tranny engine setup done in the last 5k miles or so.. it sounds like just the tranny.. its a stock diff and apparentley its got a stage 1 clutch in it.. its like a weee/whining noise only when your taking off in first or reverse.. then when downshifting it makes a little erjghh noise.. mostly only shutters when starting to reverse..
Old Aug 4, 2010 | 03:01 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
yup alot of members have that happen with various clutch setups.
I still get it on some mornings for one or 2 slips and then the wee is gone.
I never found a straight answer, but I read it has something to do with the different materials in the harder clutch setups that make noise when they contact the flywheel, especially when they are cold. always resurface/replace the flywheel for best results.
the more mileage you put on the clutch/flywheel their surfaces will actually change and make less noise. you should also notice a decrease in noise once they warm up.
I'm not saying this is 100% your issue, but its almost identical to what i went through, I was so upset i thought i blew all the money on my clutch setup to have it squeal everywhere, then I found out it was "normal" and I ragged on it till it started to go away. if you blow your trans ragging on it I am not responsible =)
Old Aug 5, 2010 | 08:26 AM
shonuff53's Avatar
shonuff53
this might be nothing at all but it depends... I say you make a video of it and post it on here, also note if the noise changes when clutch pedal is depressed or not.
IS3_FTW
General Classifieds
May 24, 2011 03:44 PM
autoboy
SC400 / 300 Classifieds
23
Jun 30, 2009 02:52 PM
Bean
Nov 16, 2005 02:39 PM
