FIRST SC MOD COMPLETED!!!! Check it out! AND I need some help.
Old Jul 14, 2010 | 07:23 AM
Shadowen's Avatar
Shadowen
Originally Posted by romycha1
Why do you need the heat on full blast?
you want the heater core turning to get any air out.
Old Jul 14, 2010 | 07:39 AM
romycha1's Avatar
romycha1
I see... I think I might have to bleed mine and do that.
In the mornings I can hear something that sounds like water moving behind the dash... Maybe there is an air pocket in there, allowing the coolant to splash around.
Old Jul 14, 2010 | 07:42 AM
NineTreSc3's Avatar
NineTreSc3
before you start the car take the rad cap off. Then run have the heat on full blast. Once the thermostat opens up coolant will begin moving through the system. Let it run for a few minutes like this. You will begin to see the coolant level drop down and you can top it off
Old Jul 14, 2010 | 08:23 AM
Shadowen's Avatar
Shadowen
If you have a large plastic hose (pref clear) you can put that on the radiator kind of as a reservoir. The air will find the highest point and will bubble out of your radiator. This can cause splashes. Hose will help prevent that.
Picture purely for reference.
bryan767
Aug 4, 2018 07:18 AM
jdmsfl305
Aug 7, 2010 08:38 AM
LSEGHATCH
Nov 3, 2009 11:13 AM
SuperiorSC
Jul 2, 2007 04:46 AM
got_trd
Nov 8, 2005 04:57 PM
