Weird problem with power steering going on/off
....I drive around for a little and find that it keeps randomly shutting off completely and then coming back on completely...very weirdSo I just got in from trying to troubleshoot/re-flush any air out of the system and it seems that it is shutting off after it drops below 500rpm's (very specific). For example, when in park and the RPM's are up, the PS is working fine..but if I put it in drive with my foot on the brake, the rpm's drop below 500 and it shuts off
even if I kick on the A/C(the RPM's jump up just a few revs) it will start working again.I thought for a second that I maybe crossed the vacuum lines that go to the PS pump/intake but I tried it both ways and the car still does the same thing.
Anyone have any idea on what could be causing this? I mean its either completely off or completely on, so it seems like a sensor/ECU thing..
BTW, Aliga helped me with some parts that I needed, great guy to do business with! Thank you!
There are some flush tutorials around - such as http://www.lexls.com/tutorials/steering/ that should send you in the right direction if this is indeed the case for you. At the very least it's a bit of inexpensive preventative maintenance that you'll feel good about having done regardless
In my case - I'm trying to find out what the top hose (the thicker one) that comes out of the power steering pump and into the fluid reservoir is called, and it's part number so I can replace mine. Mine burst open right before the clamp that hold the end to the pump it's self and barfed out all the fluid all over that side of the engine bay - fun stuff.
