Overheating problem
Old Apr 23, 2010 | 01:40 PM
FutureSC's Avatar
FutureSC
Default Overheating problem
Hey guys,
I seem to be having an overheating problem after my 1jz gets to running temp and happens when I'm moving at low speeds or stopped revving the engine. This problem goes away after getting up past around 35-40mph or so and goes back down to running temp.
I'm guessing it could be a partially clogged radiator? I just replaced the water pump, thermostat, ect. so I don't believe that could possibly be the problem.
Any input would be helpful.
Thanks in advance
Old Apr 23, 2010 | 06:18 PM
derekhale's Avatar
derekhale
do you have a fan shroud? I am missing mine and my 2j does the same thing
Old Apr 23, 2010 | 06:43 PM
FutureSC's Avatar
FutureSC
I don't have a fan shroud, but would the fan shroud really cause that much air to be redirected towards the engine? Has your 2j ever gotten up near the danger zone temp?
Thanks for the input
Old Apr 23, 2010 | 08:26 PM
good2go's Avatar
good2go
That's not what a shroud is for. The shroud is for drawing the maximum amount of air through the radiator.
Old Apr 25, 2010 | 01:20 PM
FutureSC's Avatar
FutureSC
Well then it looks like it's time for a shroud or some electric fans :P
Old Apr 25, 2010 | 02:49 PM
attzor's Avatar
attzor
I'm running a similar set up, 1jz singled (t70 though) and I never have over heating issues, I have a dual electric fan setup. Try some "Water Wetter" from redline, from what I hear it really works.
http://www.turnermotorsport.com/html...CT_ID=1-WW-12Z
Old Apr 25, 2010 | 04:05 PM
FutureSC's Avatar
FutureSC
I was actually considering getting some of that. Sounds like some pretty amazing stuff.
Jkkimjkkim
Nov 8, 2017 06:34 PM
stvmcqueen
Sep 22, 2013 06:25 PM
BBriBro
Jan 7, 2009 07:15 PM
fusion49
Nov 15, 2007 08:01 PM
DaJark
Performance
Oct 25, 2004 11:31 PM
