SAFC2 Help
Old Apr 15, 2010 | 10:54 PM
SC51's Avatar
SC51
Default SAFC2 Help
I was wondering what wire to hook the RPM (green) wire to because the one I currently have wired displays numbers that never go over a 1000. Its https://www.clublexus.com/forums/sc-...9-sc300-6.html
POST #85 I have my RPM wire to E15 -12 IGT2, but there are many other ignition wires also, could someone clarify which one is rite
Old Apr 15, 2010 | 11:26 PM
turbodremz's Avatar
turbodremz
should go to pin 58 on the ecu
look here:
https://www.clublexus.com/forums/per...ion-sc300.html
Old Apr 16, 2010 | 08:30 AM
SC51's Avatar
SC51
K thanks, ECU's are different but yours go to the IGF so I'll try that also, to set my LO/Hi throttle settings my Lo only goes up to 45? not 94 and I have the Black SAFC 2
Old Apr 17, 2010 | 09:34 AM
SC51's Avatar
SC51
Ya The IGF wire worked fine the real issue im having is under low throttle just cruising car seems to have this hesitation every few seconds and thats 14.2 A/F. Other issue is from a dead stop when I give it normal throttle to take off the car will sputter for a sec A/F s are lean like 16 -18 but quickly jumps down to normal load 14 and takes off..not sure how to tune this?
Old Apr 17, 2010 | 07:25 PM
tampa mike's Avatar
tampa mike
in those rpm columns increase your fuel number, it would be a little more beneficial to run a a tad on the rich side than lean. Go a bit richer and work your way back
sahelmad24
IS F (2008-2014)
Mar 9, 2017 07:39 PM
Excision
IS F (2008-2014)
Jun 13, 2016 02:38 PM
6SOARER
Jan 3, 2016 06:52 AM
owali
Nov 19, 2007 01:30 AM
chitwnsazn
Jun 18, 2004 06:22 AM
