DIY Tire Well Harness Relocation
Old Mar 16, 2010 | 07:46 PM
zhillz's Avatar
zhillz
I will pay someone in tampa to do this for me!
Old Mar 16, 2010 | 07:50 PM
vinh's Avatar
vinh
he just wrote a very good diy, just do it yourself
Old Mar 16, 2010 | 07:53 PM
zhillz's Avatar
zhillz
I tried this today and i couldnt get the damn fuse panel out to disconnect the harness.
Old Mar 16, 2010 | 07:56 PM
LSEGHATCH's Avatar
LSEGHATCH
Well I've decided not to cut my harness now, so much for buying all the supplies haha.
Old Mar 16, 2010 | 08:11 PM
vinh's Avatar
vinh
how low are you? If you aren't super low you don't have to disconnect the harness. Just take off the current casing/tape the harness is in so you can get more leverage from it and tug it up above the metal lip in the fender well. Once you get enough slack on it, just tape up the areas that you exposed and ziptie it up there. That's what i did and it's been fine for about 3 yrs.
Old Mar 16, 2010 | 08:33 PM
Gspec's Avatar
Gspec
Thaks for the write up! I'm newly slammed and have already ripped out my airbag wiring...lol
Old Mar 16, 2010 | 09:37 PM
snomanlex's Avatar
snomanlex
nice writeup. ive already had to redo about 10 wires due to this issue. ( If you break enough of these wires they will cause you interior lights to stay on without the key).
Old Mar 16, 2010 | 09:47 PM
Dustin2JZ's Avatar
Dustin2JZ
Are you talking about in the foot well or engine bay
I didn't even have a fuse panel in the way in the foot well
and you don't have to remove the one in the engine bay
but the plugs in the footwell are a pain in the ***
Old Mar 16, 2010 | 09:58 PM
rwdanthony's Avatar
rwdanthony
this is how i did it for myself and for TheKevin.
i thought this was much better than ben's way.
Old Mar 16, 2010 | 10:44 PM
jgdynamics's Avatar
jgdynamics
i found out that i didnt really have to do that, i just removed the fender and moved the harness above the lip and used some brackets to hold it in place. While you are in there without the fender you should also relocate the hood cable.
Old Mar 17, 2010 | 05:37 AM
zhillz's Avatar
zhillz
You unplug it from the fuse panel inside the car right? The DIY i was reading the guy said remove the (3) 10mm bolts and then unplug the fender harness from the BACK of the fuse panel? Are you guys unpluging them from inside the car without removing the panel?
how low are you?
Im tucking oem 205/55/16
https://www.clublexus.com/forums/sc-...elocation.html
This is what i did will this work?
Old Mar 17, 2010 | 06:51 AM
Jeembo's Avatar
Jeembo
Great post! Subscribed.
Old Mar 17, 2010 | 07:33 AM
mktbully's Avatar
mktbully
can the airbag wire be moved in the same fashion also?
Old Mar 17, 2010 | 10:06 AM
Dustin2JZ's Avatar
Dustin2JZ
not sure but I dont know why not
Old Mar 17, 2010 | 10:13 AM
Blkexcoupe's Avatar
Blkexcoupe
I didn't move it through the engine bay though, i simply tucked it higher in the fender well.
I did it the same way as these two. The tire is going to hit the frame before it'll touch the harness when tucked up higher, so there is nothing to worry about (unless you didn't secure it high enough).
