quality 1jz single manifold?
Old Nov 10, 2015 | 07:19 AM
chnk's Avatar
chnk
The extra thick manifold from cx racing about $500 or so, so much better than my driftmotion
Old Nov 10, 2015 | 10:44 PM
scmaluco's Avatar
scmaluco
I ran a eBay manifold on last 1jz and never had a problem.. My last 1 was heat wrapped also. No cracks nothing.
Old Nov 13, 2015 | 09:42 AM
Kris9884's Avatar
Kris9884
I will 2nd the newer CXRacing version with thick walls, they are on ebay all day with a downpipe or just order from their website. The original wasn't even that bad but this one is a beast!
Oh, you said t3.. Anything aftermarket will most always be t4 so you'd have to weld a flange or get a bigger turbo
Old Feb 24, 2016 | 07:51 PM
tjmhillz's Avatar
tjmhillz
bumping this up.. trying to see what everybody is using.. Im in the process of doing a single turbo set up and undecided on which mani to go with.
Old Feb 25, 2016 | 12:17 AM
BiGEZ's Avatar
BiGEZ
I am using the Driftmotion 1JZ manifold with no problems so far. Had to drill two of the holes to make it fit over the exhaust studs, not a big issue. You will have to modify the mounting point for the wastegate depending on which one you plan to use in order to clear the downpipe.
This is what I had to do to bolt up my wastegate.
Old Feb 29, 2016 | 11:36 AM
Rcreegan's Avatar
Rcreegan
BiGEZ-
Are you using the thick wall manifold?
Thanks!
Old Mar 1, 2016 | 07:43 AM
BiGEZ's Avatar
BiGEZ
Yes, I got their thick wall version manifold.
BigWaveSC
Dec 25, 2011 05:05 AM
Biggu
SC400 / 300 Classifieds
Mar 3, 2010 04:57 PM
plex
Mar 26, 2006 05:08 PM
2.5tsoarer
Jun 16, 2004 04:24 AM
