sway bar question
Old Jan 24, 2010 | 05:58 AM
lisc300's Avatar
lisc300
Default sway bar question
I planning on doing a GTE swap on my sc300, just want to know if id need to go with supra swaybars to clear the motor or can I go with ones that fit the sc300 directly
Old Jan 28, 2010 | 12:35 PM
v8soarer91's Avatar
v8soarer91
you can keep the standard swaybars.
if you went to supra swaybars you need to change the swaybar link-kits to supra because the mounts on the end are different
Old Jan 29, 2010 | 05:47 AM
lisc300's Avatar
lisc300
thank you for the answer
Old Jan 31, 2010 | 08:18 PM
slappy96's Avatar
slappy96
Are you using the stock IC plastic pipe that runs along the engine bay bottom. If so, you might want to look into the supra sway. A little more rear twist on the geometry give you more room for the IC pipe.
Old Jan 31, 2010 | 08:41 PM
blisiono's Avatar
blisiono
You'll need the rear subframe from a Supra for OEM or aftermarket Supra rear sway bars. The front sway bars from the Supra should bolt on fine to the OEM mounts.
Old Feb 4, 2010 | 05:54 AM
lisc300's Avatar
lisc300
thanks for the info
t2d2
Feb 25, 2015 06:45 PM
autoboy
SC400 / 300 Classifieds
19
Jan 4, 2010 05:54 PM
ToyLexmods
Nov 11, 2005 09:48 AM
SupraCoup3
Jul 25, 2002 03:30 PM
