acouple diff questions (i searched)
Old Dec 31, 2009 | 03:43 PM
topdog849's Avatar
topdog849
Default acouple diff questions (i searched)
okay my 93 sc3 diff grenaded and im searching junkyards for a replacement. sc's are so hard to come by so i found a 93 gs300. i removed all bolts as per instructions
but i cant drop the diff. the cv joints wont come off the diff after i removed all hex bolts and the drive shaft wont pop off either. i kicked and jiggled the the diff loose but something wont let it drop. is there something im missing? should i torch the cv joints or something cuz its abit rusty. do i need to unload the springs and jack up under the control arms? also whats the gear ratio? thanks
Old Jan 1, 2010 | 01:14 PM
edinlexv8's Avatar
edinlexv8
Once you follow all the above steps in your post, the diff should drop off with no problem. I did my diff last month and had no problems removing it.
Old Jan 1, 2010 | 01:47 PM
SH_JZZ30's Avatar
SH_JZZ30
Unbolt the driveshaft center support bearing by removing the exhaust heat shield. It should be very easy. 4 10mm nuts for the shield and 2 14mm bolts for the bearing. The driveshaft should drop down and give you enough room to free it from the diff.
Old Jan 1, 2010 | 06:13 PM
topdog849's Avatar
topdog849
got it done thanks, i didnt need to remove the driveshaft. turns out the cv joint were really rusted on to the diff i had to bring a big fu**n hammer and pound on the cv joints. now im trying to drop the diff i have on my car to put in the replacement but those bolts are being even harder to break loose. even with bp blaster and a torch.
cheez
Feb 25, 2012 10:45 AM
Sc3001jzTT
Jul 29, 2010 04:35 PM
bpc23
Nov 17, 2006 09:17 AM
Overclocker
Oct 13, 2002 10:17 PM
