Internal VS External Wastegate
Old May 2, 2002 | 06:58 PM
Hermosa's Avatar
Hermosa
Default Internal VS External Wastegate
Which is better and why?
Could an internal wastegate still work okay or is there a very good reason not to use one?
What is a good wastegate to buy? How much should I pay?
Old May 2, 2002 | 07:31 PM
SC300T's Avatar
SC300T
HKS makes very expensive ones, but very high quality.
Turbonetics wastegates are cheaper but are known not to hold up under the highest boost levels.
Integrated wastegates tend to leak boost at higher PSI, in general...
The majority of the big HP Supras use an HKS external wastegate.
Old May 2, 2002 | 08:51 PM
Hermosa's Avatar
Hermosa
What if you only want 8-12 psi? Will they work fine?
Old May 2, 2002 | 09:33 PM
quick's Avatar
quick
Buddy of mine just finished a T-88 install on his Supra... external HK$ wastegate that sounds absolutely insane.
Talk about instigating a race...!
Old May 3, 2002 | 09:53 AM
Bean's Avatar
Bean
CL Folding 1,000,000
yup; low boost is fine; in fact toyomoto's external that they ship with their kits is setup to open at 5psi
Old May 3, 2002 | 10:04 AM
Hermosa's Avatar
Hermosa
Thanks guys.
Is it easy to set the internal wastegate settings or do you have to buy a new one set for that? I don't know much about this stuff but I'm learning.
Old May 3, 2002 | 01:49 PM
Bean's Avatar
Bean
its about the same in difficulty; in both instances you have to replace the spring to set the base psi level
you can always increase the boost with a boost controller however; its just how controllable the boost is... the higher the boost base setting is; the easier it is to control higher level boost
94_soarer
SC400 / 300 Classifieds
Oct 30, 2015 08:33 AM
Styx
IS - 1st Gen (2001-2005)
Jan 30, 2005 09:57 AM
indypwr
Mar 10, 2004 11:34 PM
LexSteele
Mar 27, 2003 12:21 AM
stick
Feb 11, 2002 06:24 PM
