Which double din navigation system are you guys using?
I tried doing a search but nothing really came up. Were you guys able to retain the stock subwoofer and speakers?
Not too bad actually, took around 2 - 3 hrs checking the diagrams and seeing what needed to be hooked up. After all that install was pretty straight forward. Cut a few, strip a few, connect a few wires and good to go haha. I think there might be a harness available now but not sure on that.
OT: you get the SC tuned yet? haha
With the center console out and the ebrake boot off, you'll see a single black wire running to it, which is the wire for the ebrake, and i'm sure if you look down by the brake pedal you should see a wire somewhere for the brake.
I'm not sure on where the wire is for the brake pedal as I never tapped either the ebrake or brake. I just put in a bypass and didn't worry about them haha
PhilipMidd
Aug 6, 2019 05:30 AM
freshmoney
GS - 1st Gen (1993-1997)
17
May 9, 2011 09:54 AM
Benbendx
37
Apr 13, 2011 09:30 AM
stock4now
Jan 6, 2005 11:01 AM
