polyurethane trans, engine, subframe and diff mounts/bushings for soarer
As the title states, I want to replace the trans, engine mounts and diff and subframe bushings on my soarer with something stronger. I am pretty sure the engine or trans mounts are already shot, want to replace everything while I am at it.
Already did all the control arms, traction rods, toe links and steering rack.
Which cars would have interchangeable mounts? My soarer has an r154 so I guess the MKIII supra trans mounts will work? Will 2jz engine mounts work? Where can I get diff mount bushings? Also, I am assuming the supra MKIV subframe bushings are also compatible.
The engine mounts in the Soarer / SC300 are exactly the same as the MKIV Supra. You can get new OEM, TRD, Kazama, or even solid billet mounts.
Sorry, I can't help with the aftermarket trans mount. If you find one, LET ME KNOW!!! Hopefully someone runnin' a R154 in their car will chime in on fitment.
A good spot for supra stuff is mvpmotorsports.com.
I have a 97 5spd, so I have the "late" model engine mounts. I have Kazama mounts with a new OEM trans mount.
^ thanks that was very useful info!!
MKIII r154 poly mounts are readily availible, not sure if they will fit a soarer though..
