1uz-fe (71, 76mm turbo spool)?
hi, on our 4.0 L 1uz- if we had a single turbo with a 71 mm and another at 76 mm (two different applications- NOT twin turbo)... how fast would it spool up? start to build boost and how fast would it hit full boost?
on a 3.0L 2jz-gte.. when i had the 76mm turbo, it made full boost by 4800 RPM.. (in 4th gear) so i'm curious what it would do on a 4.0L 1uz... ???
i wanted to know which application would suite me better... if i should go with the 71mm or a 76mm turbo on the 1uz...
thanks
thanks
From: Marietta, Georgia / Charleston, South Carolina
It depends on your other mods as well...I mean, you can always use nitrous to spool the turbo too. I guess you kind of need to be more specific on the setup and what you're looking for
