Is there ?
Old Apr 23, 2002 | 05:05 PM
lex1997's Avatar
lex1997
Default Is there ?
Is there any way to smoke or at least stay even with the 1992 3000gt vr-4. or CLK430 with my 1992 SC400
I'm sorry for this stupid question, I know that VR-4 is alot faster than my 1992 SC400 but what about CLK430.
What if I have weapon-r ECU , Intake,Exhaust,TC ( but no NOS)
The VR-4 is all stock.
Thanks.
Old Apr 23, 2002 | 05:54 PM
DriftGirl's Avatar
DriftGirl
........you had better be on the bottle
Old Apr 23, 2002 | 07:04 PM
SupraCoup3's Avatar
SupraCoup3
either that, or trade your SC400 for a SC300 5sp and turbo the puppie.
VR-4 is a quick mitsubishi....
3000GT VR4 Specs
3.0 Liter V6 DOHC 24 valve
Twin turbochargers and twin intercoolers
181 cu in w/ 8.0:1 compression
Electronic controlled MFI (multi-point fuel injection) with twin spray injectors
320 Horsepower @ 6000 rpm, 315 lbs.-ft. Torque @ 2500 rpm
(capable of up to 750hp with stage 1 - 4 kits)
Engine redline - 7000 rpm
4 bolt main bearing caps with forged steel crankshaft
Full time all-wheel drive with center differential and electronic traction control
Limited slip rear differential
4 radiators with dual fans (engine, oil, and two turbo coolers)
Power assist rack & pinion
Transmission - 6 speed with overdrive
4 wheel steering (same phase) w/ traction control computer
4 wheel disc with 4 piston calipers
Non-asbestos linings
Air pick-ups (4) for disc ventilation
All wheel ABS system with G force sensor, 2 channel system
minimum stopping distance 122' @ 60 mph
minimum stopping distance 218' @ 80 mph
0 - 60 mph : 5.4 seconds
0 - 100 mph : 13.6 seconds
(stock times)
Lateral acceleration on 200' skidpad = .90g
1/4 mile - 13.7 @105 mph
(stock times)
5th gear@6220 rpm - 155 mph
6th gear@4990 rpm - 160 mph
Engine redline - 7,000 rpm
Speedometer runout @ 180 mph
Weight - 3781 pounds
Fule capacity - 19.8 gallons
Drag coefficient - .33 Cd
Wheelbase - 97.2 inches
Length - 179.7 inches
Width - 72.4 inches
Height - 49.3 inches
Interior Noise:
Idle - 46 dBA
Max, 1st Gear - 70 dBA
70 mph - 69 dBA
11.12 lb\hp
Stock, you'll have a tough time beating him w/ your SC, unless you got a bottle.
Old Apr 23, 2002 | 11:27 PM
1BomexLex's Avatar
1BomexLex
yeah...but when does USA get the EVO lancer over here
that thing will be even more of a beast once it is released
we need a japan market sooo bad
all their cars are Turbo
most are all wheel drive
at least the modifying cars are
not counting the grandma cars
u know
Old Apr 24, 2002 | 12:17 AM
TheKevin's Avatar
TheKevin
CL Folding 25,000
The VR4 is one heavy car.
Old Mar 20, 2008 | 06:47 PM
DreamWhoop's Avatar
DreamWhoop
but its nice lol especially if ya have a hard top spyder..
1WILLY1
Sep 26, 2010 01:00 PM
Righteous
Mar 23, 2006 03:09 PM
Drewski
Apr 2, 2005 11:33 PM
AzNRR_12
Sep 3, 2002 11:17 PM
cundiffw
Feb 28, 2002 06:26 PM
