problem with factory alarm...help please
Old Sep 13, 2009 | 06:50 PM
roadkill5o's Avatar
roadkill5o
Default problem with factory alarm...help please
when i bought my car back in may the alarm was working fine, id lock the car and the alarm would turn on...then one day it just stopped turning on when i lock the car...the doors will lock but the security light wont blink like it did before, and the alarm wont turn on if i unlock form the inside by hand when the car is locked, when it should...now my question is. Is there a fuse for the alarm system that for some reason may have gone out? What other reasons could cause this?
Old Sep 15, 2009 | 12:47 AM
roadkill5o's Avatar
roadkill5o
nobody????
Old Dec 12, 2009 | 06:39 AM
mousiee's Avatar
mousiee
I hate to revive this old thread, but i have the same problem. My alarm seems not to be working. The keyless entry works but not the alarm. Can anyone shed any light on this issue?
Old Dec 12, 2009 | 07:11 AM
Scotty's Avatar
Scotty
Toyota and Lexus vehicles arm their alarms on lock once all doors are closed. That said, I had an LS400 with a bad driver door pin that would sometimes not arm and worked again with the replacement of the pin switch. The SC400 door pin is built into the door latch.
I'd check to see if your dome lights work with both doors. If the dome light comes on with both doors it's time to test the system by locking and closing all doors. Once the security light has gone from solid to blinking (takes roughly 30 seconds to fully arm), test the alarm by reaching in the window and unlocking the door, that should set off the alarm.
If your dome lights come on and alarm still isn't working, then there is a good chance something in the alarm module isn't functioning as it should be. It may be cheaper and less time consuming to just replace it with an aftermarket alarm/keyless rather than mess around trying to fix the factory one, assuming everthing else is working.
Old Dec 13, 2009 | 03:11 PM
mousiee's Avatar
mousiee
I followed your instructions and come to find out my alarm does work. I guess I didn't let the alarm set when I tried it before. Thanks for your help!
Mousiee
Old May 5, 2010 | 11:02 AM
se_bb2's Avatar
se_bb2
I have a similar problem, my security light is blinking but power door lock just stopped working. I'm not able to turn off the alarm with my key anymore on both doors. I can't turn on my car neither due to that i believe. is it my alarm module not functioning correctly anymore? or a bad fuse? need new door latch?? I been fighting this for 2 days already. I need to fix this any suggestions will be greatly appreciated ! thanks
bhood2017
Sep 14, 2017 05:36 PM
FiveSeven
Nov 28, 2016 03:54 PM
tedsterb
Dec 10, 2014 08:42 AM
BigWaveSC
May 29, 2006 04:02 AM
