Tachometer problem with J-spec 2JZGTE
Old Aug 20, 2009 | 07:31 PM
2JZGTE SC's Avatar
2JZGTE SC
Default Tachometer problem with J-spec 2JZGTE
I swapped a J Spec 2JZGTE into my '94 SC. The shop who installed it claims that it is not possible to have the stock tachometer read the J Spec RPM. The reason they gave me was because of analog/digital signal from the US tach and J SPEC engine.....It sounds bizzare.
I have had my tach @ zero rpm for too long now. I have been using a heads up display since.
So Does anyone one know if it is possible to have the tach read the engine speed with the J Spec.
Thanks
Old Aug 21, 2009 | 04:27 AM
wanganstyl's Avatar
wanganstyl
yes, look for R109 in threads, jump the resistor in the guage cluster and you should get a reasonable accurate rpm signal. OR you can use the dakota digital tacho adapter- thats what DR tweak sells and uses.
J-STAR
Aug 20, 2009 03:06 PM
b00b00s559
Feb 19, 2006 06:36 AM
