SC400 alternator
Old Jun 25, 2009 | 12:34 PM
TRD_Power's Avatar
TRD_Power
Default SC400 alternator
Well I had zero luck with this question in the maintenance forum, but I'm sure someone here will be able to answer it. My alternator went out and I am looking to replace it with a Denso, but the site I found has two different options for the plug in the back, but they claim both work... I don't see how they would both work when they are THAT different looking. I put red circles around the two plug spots. The question here is which would be the one to get for my '95 SC400? Thanks everyone. Oh yeah and I am unable to remove it for a while to check myself, just want to order the right one and do it all at once.
Old Jun 25, 2009 | 02:04 PM
kanderson's Avatar
kanderson
You need Denso part number 210-0173. That is the only one for the 95 SC400. I hope that helps. Which should be the oval plug design. On your picture it is the one on the left.
Old Jun 25, 2009 | 08:30 PM
PERRYinLA's Avatar
PERRYinLA
Default I just worked on mine, so I know....
....and for the 1992 SC400, it's the one on the right, so the design must have changed in 94 or 95.
Old Jun 25, 2009 | 10:03 PM
ihiryu's Avatar
ihiryu
a bit off topic,
the oval plug is also used by the supra TT, while the aristo and 1jz use a circle plug
Old Jul 17, 2010 | 08:08 PM
CLRH2O's Avatar
CLRH2O
So wait - is it the round plug for a 1993 SC400 then?
Old Jul 18, 2010 | 12:37 AM
xxtoobsxx's Avatar
xxtoobsxx
I know you can buy any of the 2, and swap the plugs from your current alternator. How munch they charging you? I have an extra alternator....
LomoFire
Oct 29, 2013 03:49 PM
royaltyrsp
Dec 26, 2009 01:52 PM
TRD_Power
SC400 / 300 Classifieds
Jul 17, 2009 07:19 PM
hansjl
Dec 6, 2007 07:46 AM
1tym
Apr 8, 2004 05:41 PM
