Oil Return Line
Old Jun 16, 2009 | 06:04 AM
SC2JZ300's Avatar
SC2JZ300
Default Oil Return Line
Yes I have searched. The only answer I got was I need to accommodate it.
Facts...
1JZ with a front sump converted into a rear sump. Now the oil return lines do not line/match up.
Question is, how do I get it to line up and can I just by a US Spec oil return line?
Sump conversion is from an 2JZGTE(US Spec). Thanks.
Old Jun 17, 2009 | 01:43 AM
bodydrager's Avatar
bodydrager
I ran into the same problem when i converted mine. I had to bend the lines that run from the turbos and modify the bracket that is running along the side of the block so that I could connect the hoses. It took me around an hour to do everything and install new hoses. This was probaly the hardest part of the whole swap and a pain in the a$@.
Old Jun 17, 2009 | 10:13 AM
SC2JZ300's Avatar
SC2JZ300
That was going to be my last option. Anyone else?
Old Jun 17, 2009 | 10:42 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
custom return line? just get the right fittings and make your own line. its probably not that hard. I made mine from scratch for my na-t.
you can order everything from JEGS or Summit Racing for pretty cheap.
pd-cuevas
Nov 26, 2010 10:04 AM
CP_Ree
Dec 29, 2009 08:29 AM
SC2JZ300
Jul 30, 2009 10:19 PM
SuprRunner
GS - 1st Gen (1993-1997)
Nov 10, 2005 08:08 AM
