Headlight Disaster
Old Mar 25, 2009 | 09:23 PM
Lo2's Avatar
Lo2
Default Headlight Disaster
So i washed my car today.
Then it happened....
F-in condensation in my driverside headlight.
What should i do & how should i do it?
heres the light
&heres a chip, with a tiny hole.
idk if you can see it. its to the left. right by the opening where the turn signal goes.
&heres a spot on the top of the light, where it looks like the sealant wore out.
& maybe i sprayed water in there. ?
Old Mar 25, 2009 | 09:26 PM
Amini9's Avatar
Amini9
CL Folding 200,000
buy a new one!
tuterz's Avatar
tuterz
mine looks pretty much like yours.. im gonna try the breather thing soon
Old Mar 25, 2009 | 11:13 PM
vwynn's Avatar
vwynn
first you do a search about headlights and how to open it + clean it + seal it.
Old Mar 26, 2009 | 04:44 AM
ThomasGS4's Avatar
ThomasGS4
Originally Posted by Amini9
buy a new one!
bleh nice try. Unseal, clean, reseal for a perfect fit. Make sure there's a filter there. If not, then you can use either a cotton ball or try UZZ30-SC4's trick with the mini air filters
Old Mar 26, 2009 | 09:22 AM
SC_coupe's Avatar
SC_coupe
Buy a used one. I removed and re-sealed my right one twice, but it would still fog up. I found a used one in good shape at the scrap yard that hasn't fogged up for the 8 months I've had it. Well worth $90 to me.
Or you could reseal and make some breathers, like in UZZ30-SC4's thread.
Old Mar 26, 2009 | 11:24 AM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
make sure it is sealed tight and that the breather apparatus works...I've had to reseal mine a billion times only to find out the breather tube is all clogged up...now it's fine and dandy
Old Mar 26, 2009 | 11:26 AM
mr2tosc4's Avatar
mr2tosc4
reseal that first then try the mini filter thing or just drill holes in the underside like i did. almost a year now and still good, use a very small bit and drill like 20 of em
Old Mar 26, 2009 | 11:32 AM
Erukian's Avatar
Erukian
i did a reseal on one of my headlights a year ago and it's still fine today, i the breather hose thing on the underside just broke off and i haven't put any filter on there, is it just collecting dirt now?
Old Mar 26, 2009 | 11:45 AM
VJZ's Avatar
VJZ
I'm happy with my black housing ones through eBay.
But...this topic has been discussed over9000 times before. OLT did a good write up that you can look at.
Old Mar 26, 2009 | 02:08 PM
SC300_704's Avatar
SC300_704
i drill like 5 2mm holes on the bottom..helps it breaths better
Old Mar 26, 2009 | 09:57 PM
Kaydee's Avatar
Kaydee
with that much water inside I think water is seeping in through the hairline cracks
Old Mar 26, 2009 | 10:10 PM
CrazySC300's Avatar
CrazySC300
I have a pending deal with someone here to work on my headlights...
Old Mar 27, 2009 | 05:51 AM
felixsc300's Avatar
felixsc300
Or you can just park it in the hot sun every time you wash the car, but it would be a hassle. Though when the weather is wet and cold in the winter this method would obviously not work.
I've had condensation in my driver's side headlight since October and it has dried up a lot now. I'm too lazy/scared to open/clean/reseal the headlight unit.
Old Mar 27, 2009 | 05:10 PM
parnzen's Avatar
parnzen
its not hard to open it and reseal it. search for the diy thread on it and follow its instructions
xsrhaym
Feb 15, 2018 12:30 PM
itsivan
May 6, 2013 11:21 AM
CCLSVTF
IS F (2008-2014)
12
Dec 23, 2012 09:54 PM
LAMF
Sep 4, 2006 02:00 AM
OakTwnPnoy
Oct 1, 2005 09:13 PM
