B-ver's Build Thread
Old Feb 26, 2009 | 09:16 AM
  #61
BattleVer's Avatar
BattleVer
I was considering making solid rear bushings but I may be making subframe spacers. Just cause its easier to install then having to take your entire rear apart to change things out.
I like oem tie rods as well. The aftermarket stuff doesnt seem to hold up as well.
I'm just using regular sand for the media blast. I know the soda stuff is cleaner, but these guys have alot of undercoat to get threw.
Old Feb 28, 2009 | 08:10 PM
  #62
BattleVer's Avatar
BattleVer
Got the car back from the blasters and dropped it off at a freinds shop. I was too busy to even think about taking pics but the inside is nice and clean. The undercoat is still there. Thinking about just using rustoleum on the bottom of the car just to save time. I dont think people care really what the underneath of a car looks like.
Saturday and my machinist helped me out alot. We took all day but got all the delrin bushings fitted and made. I couldnt ask for a better job as these things fit so nice. Time for some pics,
Here is Kevin trying to run from the camera...
Just one of many rows of machines
Some delrin getting turned
What they looked like after
Even made some rack bushing replacements
I'll take some pics of the stuff installed when I put it all together. We didnt have enough material to make an extra set so I left one side with him to get pricing for more kits.
Old Mar 1, 2009 | 02:14 PM
  #63
Biggu's Avatar
Biggu
alex like we talked about let me know when you get more made of the steering rack made as i will need a set.
Old Mar 1, 2009 | 04:37 PM
  #64
BattleVer's Avatar
BattleVer
Should be a little while before I'll have anything if you dont mind waiting.
Old Mar 2, 2009 | 10:19 AM
  #65
DRFT103's Avatar
DRFT103
Alex, if you made battle version solid steer rack bushings for soarer/mk4.. i think they'd do well. I know I'd buy a set.
Old Mar 2, 2009 | 04:23 PM
  #66
BLK13X's Avatar
BLK13X
For Mind Cruising
Very nice, loving all the custom work
Old Mar 2, 2009 | 08:55 PM
  #67
BattleVer's Avatar
BattleVer
For now, I'm just going to worry about getting the car done, then I'll worry about making parts.
Picked it up, And there was sand in every hole and crevis. Next time I'm just going to have the car dipped. It costs more but at least it's alot less work to do to prep the chassis. So far I've wasted a few days cleaning things where it would have been done already if it was just dipped. Now I'm worried that the sand would come out when it gets coated and mess things up. O well, here is what it looks like.
Old Mar 2, 2009 | 08:59 PM
  #68
cartmill's Avatar
cartmill
just get a vacuum to suck the easy to reach sand, then blow the rest out with some compressed air.
also, this is one of the reasons people like to use different types of media (read: not sand) that will actually dissolve with water. so you can clean most of it out, and let some water dissolve the rest.
Old Mar 3, 2009 | 09:43 PM
  #69
BattleVer's Avatar
BattleVer
Yeah, live and learn I guess. Probably took out about 30lbs of sand so far.
O well, next update. Started off the day cleaning of coarse. Then moved onto to some dimple die plates.
Started off with some generic cut outs and trimed to fit.
Then cut some holes where I wanted the dimples and cleaned the holes and the metal.
Then some dimples, yes I was cheep when I bought my set. I should of gotten the ones that cut the holes and dimple at the same time.
Then installed, well welded in.
And the far view.
Then got back to some of the other things on the cage. I ordered some 1 1/2 x .083 wall to do the rear braces, but they hopefully will be here tomaro. So I used some 1 1/4 x .083 wall and made some braces for the fender braces. Yes braces on braces, the more bars, well not always better but always heavier. I did need to triangulate those things for some strength.
Didnt weld them in yet cause I now have a new rule, no welding once the sun goes down. For some reason, maybe its my eye sight, but it just doesnt come out as good.
Old Mar 4, 2009 | 07:25 AM
  #70
TheRonTom3's Avatar
TheRonTom3
Originally Posted by TheRonTom3
Alex (can't afford dimples) ???
lol
I retract my previous statement
Old Mar 4, 2009 | 08:32 AM
  #71
DRFT103's Avatar
DRFT103
it's so sick watching this car come together! keep it up!
Old Mar 4, 2009 | 08:43 AM
  #72
sphy1005's Avatar
sphy1005
Love the build. Very thorough. Keep it coming
Old Mar 4, 2009 | 12:26 PM
  #73
jimmyXthai's Avatar
jimmyXthai
nice build
Old Mar 4, 2009 | 01:25 PM
  #74
rwdanthony's Avatar
rwdanthony
deumm thats nice. i love seeing build threads like these. similar to the fab thread on nico. cant wait to see the turn out.
very nice on the bushing/spacers as well. i want to get a full car set soon.
Old Mar 4, 2009 | 01:47 PM
  #75
chrisngo's Avatar
chrisngo
Alex,
Are you tigging or migging? What is your setup?
Chris
