Camshaft question
Old Jan 12, 2009 | 12:47 AM
shamblix's Avatar
shamblix
Default Camshaft question
Can I use JDM camshafts from a 6spd supra in a USDM sc300 5sp?
Old Jan 12, 2009 | 09:26 AM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Need to find specs on that cause that is a real technical question. Ask on Supraforums if anyone has specs on the Supra cams. Then ask someone on here if they have specs for that. Then you should have your answer.
Old Jan 12, 2009 | 10:18 AM
5sp_jzz30's Avatar
5sp_jzz30
you can use jdm 2jzgte camshaft in a usdm 2jzgte. but you dont want to do that though. the usdm 2jzgte cams are actually a bit more aggressive.
you cant use 2jzgte cams in the 2jzge. at least you can use the exhaust camshaft. the intake cam will work. the exhaust cam in the 2jzge has a helical gear cut into it to drive the distributor and the the 2jzgte cams dont since they dont have a distributor and use coil on plug system.
i dont know that a jdm 2jzgte cam would be much of an upgrade to a 2jzge.
if you google or search here or supraforums you can find info on aftermarket cams for the 2jzge that has a helical gear on it. i believe user Cowboy either makes them or sells them. PM him for info.
gs300F
Oct 23, 2015 12:37 PM
tonysc400
SC400 / 300 Classifieds
May 21, 2015 01:52 PM
americk22
Jun 12, 2011 06:02 AM
bmsc300
General Classifieds
Jul 31, 2010 09:00 PM
DavidSupra
Jan 5, 2003 11:05 PM
