noise when turning right...
Old Dec 23, 2008 | 12:52 PM
SC300_704's Avatar
SC300_704
Default noise when turning right...
it just started making whining sounds whenever i make a hard right turn, could it be LCA bushings? i've already replaced front UCA bushings, steering rack bushings and sway bar bushings...
Old Dec 23, 2008 | 09:14 PM
KC95SC400's Avatar
KC95SC400
Power steering pump whine?
Your not far from me, I'd be happy to look at it.
KC
Old Dec 23, 2008 | 09:26 PM
rwdanthony's Avatar
rwdanthony
did you change your ride hieght? what was the most recent change before this happened in your car?
Old Dec 24, 2008 | 08:17 PM
SC300_704's Avatar
SC300_704
KC
i'm guessing it could be the power steering pump too..it also kinda feel and sound like there's metal rubbing eachother...if i can't figure it out then i might need your help...
Old Dec 24, 2008 | 08:20 PM
SC300_704's Avatar
SC300_704
naw..the height as always been the same ever since i bought it, the most recent major change that i did on my car was changed the clutch...
Old Dec 25, 2008 | 05:15 PM
KC95SC400's Avatar
KC95SC400
lmk.
Kc
Old Dec 26, 2008 | 06:20 AM
hitsolid's Avatar
hitsolid
My 93 SC300 was doing the same thing. The noise was only made when turning right. The shroud in the drivers side wheel well was loose. You may want to check your wheel wells for loose shrouds.
brainsurge
Suspension and Brakes
Nov 6, 2014 07:20 AM
ALLWiTE2JZ
Dec 27, 2012 09:31 AM
AnonymousG
Feb 28, 2012 08:42 PM
rwdanthony
SC400 / 300 Classifieds
21
Sep 21, 2011 10:38 PM
eliteskill
Jul 9, 2011 11:22 PM
