struggle upon accel
Old Dec 28, 2008 | 06:26 PM
ConSynX's Avatar
ConSynX
used, junkyards...etc
I have 1jz inectors that you could have them, rail, and regulator for $20, but i dunno if they work, or how close they are flow-rate wise.
Old Dec 29, 2008 | 08:27 AM
tylka's Avatar
tylka
how do you check the injectors
Old Dec 29, 2008 | 10:18 AM
ConSynX's Avatar
ConSynX
some places that sell aftermarket will do a bench flow-test. . .
not sure if they do it for oem's, but if not any place like that should do, and it's fairly cheap iirc.
Old Jan 10, 2009 | 09:32 AM
sccd's Avatar
sccd
Default rough idle fixed
Originally Posted by sccd
my 92 sc400 idles real rough, and runs rough while driving at low rpms. Once I get to about 3000 rpm. it smoothes out and runs great. When the car is stopped, it almost will stall. If I accellerate hard, the engine really sounds like it is baffled and barely has power. Wondering if our problems are caused by the same thing.
Problem fixed. Ends up that a coil was intermittent under load. Took a master mechanic 3 hours to diagnose and replace a coil. Two other mechanics had given up on it. Thanks to all you who gave me suggestions! I now have a used MAF for sale that I bought from a member, thinking that was the problem originally.
NiceSC400
May 14, 2013 08:17 PM
Oconee1985
Apr 26, 2013 05:44 PM
92lexus
21
Jun 18, 2012 05:10 AM
SuperCoupe400
Feb 25, 2011 10:32 AM
RedPhoenix
Oct 7, 2009 10:02 PM
