94 SC400 Heater Control Valve?
Old Nov 16, 2010 | 02:59 PM
Klaus's Avatar
Klaus
Alright well I noticed something wierd. I definitely have a bad heater control valve. I bypass it for the winter and the heat works, otherwise it doesn't. But the heat will only get hot if the engine is over around 2000RPM. Under that (so cruising or idling) the heater blows cold air. AC button is off. Outside temp is around 50*. Can't figure out what this would be?
Old Dec 3, 2010 | 07:20 PM
S142jz's Avatar
S142jz
Has anyone taken the Valve apart ??? Mine is leaking but my Heat still works.
Old Dec 7, 2010 | 06:31 PM
Jujharoo's Avatar
Jujharoo
Originally Posted by 94SC4
My 94 SC4 just had the same problem. There is a diag test for the VSV which controls the actuator on the water control valve. However there is a simpler test. If you take the vacuum hose from the VSV and plug it directly into the actuator and you now get heat (engine warm, wait a minute or two), then your VSV is bad. See the two photos below. First photo is how the vacuum hoses should be routed. Second photo is the re-routed hose directly to the actuator. A local lexus gave me the following part numbers 88690-24060 ($225) for the VSV and 87240-24040 ($325) for the whole water control valve unit. It's much less at Carson's and I just ordered my VSV today. By the way, if you keep the hoses rerouted, you'll lose cooling efficiency when it gets warm outside but it's a good alternative until the replacement part(s) come in.
This has been a life saver. Thank you.
Would buy you a beer if you were from around here.
Old Nov 2, 2011 | 05:12 AM
bpitarresi's Avatar
bpitarresi
Saved $865 Heater Control Valve Replacement by Lexus Dealer. After reviewing your pictures, I tested the valve by changes hose connections as instructed. Heat came on. However the short hose 45 degree hose has a plastic connector. I removed it and found the connector was collapsed. Replace the connector with a piece of hose I had lying around and it now works like new. So, before replacing the Heater Control Valve check the short 45 degree hose connection for clogging or collapse.
Old Nov 3, 2011 | 04:25 PM
CLRH2O's Avatar
CLRH2O
Hello all
I'm in a similar situation with my Heater Control Valve. But in my case, the water inlet has broken off of the housing of the valve it's self. In the picture below you can see the inlet port circled by yellow, and where it's broken off shown in red dashed. And the blue is what I'd like to replace without having to purchase any of the other stuff which is still working.
1st, is that even possible? Buying the central plastic part ONLY. And if not - what's the deal with all these I see everywhere online as *replacements* for the whole Heater Control Valve assembly:
Because these little suckers are 20 bucks as opposed to $400.
Check this shop here it's got both:
http://www.drivewire.com/vehicle/199...control-valve/
Old Nov 3, 2011 | 04:58 PM
over40driv's Avatar
over40driv
Your going to have a hard time mounting that on the bracket. Other than that give it a try.
Old Nov 3, 2011 | 05:40 PM
over40driv's Avatar
over40driv
It has to be used in conjunction with the vacumn switch valve.
Old Nov 3, 2011 | 05:57 PM
CLRH2O's Avatar
CLRH2O
Using the images I've shown above, can you explain what parts would be used from the old assembly *with* this new cheapo part *if* it were to even work at all?
big thanks man
Old Nov 6, 2011 | 06:17 PM
CLRH2O's Avatar
CLRH2O
Anyone on this? Can anyone explain how you'd integrate this little 20 dollar part in place of the central plastic valve part of the OEM assembly?
If i'm understanding this correctly, that's what the process would be if I got one of these 20 dollar parts listed / shown / linked to above.
Old Nov 6, 2011 | 09:41 PM
MooJohn's Avatar
MooJohn
OLT has pointed out a far cheaper replacement in this thread.
I'll go with this replacement when my valve gives up the ghost. There's no reason to hang onto a Lexus branded part for something as simple as this.
Old Nov 7, 2011 | 11:22 AM
CLRH2O's Avatar
CLRH2O
100% Genius. You and OLT are de men 'dem!
F that little metal part I'd found. And F the Denso $400 one too.
Thank you - I'm off to go find one of these now wikkid!
I'll report back here once I get one about how much it is right now end of year 2011, where from and again once it's in with any install notes and afterward operating comments.
ez ---CLRH2O
Old Jan 5, 2012 | 08:48 AM
IIJZSC300's Avatar
IIJZSC300
I just tried doing this now I just had my gte swap done not sure wtf happen but it looks like its not even plugged in I can't seem to find the clip that it plugs in to as well please help I'm freezing my *** off
Old Feb 20, 2012 | 03:54 PM
boobstar's Avatar
boobstar
I tried the bypass method and still had no heat. That would mean its not the heater control valve right? What should I check next?
Old Feb 20, 2012 | 04:53 PM
imDementeD's Avatar
imDementeD
^ make sure you have vacuum , i did the "fix" and nothing then later fiddled with it again and noticed the valve was working(by pressing on it with my finger) and then took the vacuum line off it to realize i had no vacuum at all, went straight off the manifold and viola ..heat!!
Old Feb 20, 2012 | 05:21 PM
boobstar's Avatar
boobstar
How did you notice the valve was working by pressing on it? Also which line should I be checking for vacuum, the vsv line? When you found that it didnt have it, you just t'ed off one going to the manifold you're saying? Thanks in advance. It just got a little cool out here in FL didnt it?
