Sc400 engine stutter
Old Jul 26, 2008 | 12:30 AM
2700$oarer's Avatar
2700$oarer
Cool Sc400 engine stutter
Hi everyone. I have a 93 Sc400 that I just recently saved from being sent to a scrap yard.... I have completely fixed all the damage to it so to my question.... It was running fine since I got all the repairs done to it about three weeks ago... Since then I have cracked my radiator, already have a new one. But as of about a week ago I get this dreadful stutter when accelerating... At first I thought it was the transmission by the way it felt, so I did the little quick flush two quarts out of time.... Then it started shifting way smoother and low a behold the stutter comes clumping back.. Mainly when accelerating from a dead stop at lights with rpms around 1300+ then stumble, stumble, more pedal then goes away. No problems oddly at 60mph and up though? I also notice I have lost alot of power, but no engine light yet? The car has 101k on it now.. starts and idles perfectly fine.. any help would be greatly appreciated this is the first import car I have ever had... Thanks!
Old Jul 27, 2008 | 07:50 PM
over40driv's Avatar
over40driv
Low RPM hesitations seem to occur with the 400. Some say its the MAF, which you might try spray cleaning it. Of course you should have a new fuel filter, which can be a hassle to change. If I ever pull my intake manifold to change the starter, Im going to get my fuel injectors cleaned and flow rated. P.S make sure no vacumn line leaks.
Old Jul 28, 2008 | 08:39 AM
kyoso23's Avatar
kyoso23
I recently went through this with my '97, turned out to be a fraying coil wire. Give that bad boy a tune up and it'll be good I'm sure.
Old Jul 28, 2008 | 01:29 PM
cbrasian's Avatar
cbrasian
if you have access to a scan tool check out the imputs from the comp check the maf and check the coil wires also is most likely electrical side
Miked1110
Nov 4, 2018 03:05 PM
shoom88
Apr 23, 2015 05:57 PM
devinb30
Jul 20, 2012 03:35 PM
ballhooter
Oct 10, 2011 12:27 PM
ojas
Jun 21, 2006 08:05 PM
