Koni users please check in...
Old Jul 22, 2008 | 12:04 AM
Peter_95's Avatar
Peter_95
Default Koni users please check in...
i was wondering what springs you guys are running and on which perch you guys have it set to.
please mention if you are on koni's for a supra or an SC.
Thanks....
please post pics also if you have them....
Old Jul 22, 2008 | 01:41 AM
TheMole's Avatar
TheMole
There is no Koni yellow application for the SC in the US so they have to be the Supra versions.
Not sure if this is applicable, but I used to run Supra spec Swift springs and Bilstein HD shocks. The handling was great and would have been better if my front lca bushings weren't shot.
I believe user Sly Guy Yu is currently running the Swift/Koni combo.
Old Jul 26, 2008 | 08:44 PM
Yahoo27's Avatar
Yahoo27
Im running Eibach (supra) springs with koni yellows (supra). The shock setting is in the middle, the spring perch sits on the lowest settings. I have 18 inch vr4 wheels and my front rubs sometimes when i turn.
Old Jul 26, 2008 | 08:47 PM
Yahoo27's Avatar
Yahoo27
Here's a thread with some pictures of my car with the setup.
https://www.clublexus.com/forums/sho...d.php?t=357053
Old Jul 28, 2008 | 11:35 AM
Peter_95's Avatar
Peter_95
oh icic.... i just set my rear on the lowest one, but on the front, i had to go on the higher one since i was rubbing like a mad man, but the drop seems very even actually.
How do you adjust the dampening on these shocks? does it really need to be off the car?
Old Jul 29, 2008 | 04:18 PM
Yahoo27's Avatar
Yahoo27
Unfortunately the shocks has to be off to adjust them, I don't know why they didn't add the adjustment **** feature on the supra ones because they did it for almost every other application. Theres a button you push in by the piston shaft. Push the button down and turn the piston shaft you'll feel the clicks, if you turn it all the way counter clockwise until it doesn't stop clicking thats the softest setting. Turn it clockwise makes it stiffer. Theres only four settings so theres only 3 clicks to go if you want it super stiff.
Mines in the middle, it's pretty comfy and at the same time not much body roll as stock. I'm going to have try raising my front, I cant turn fast :/
I was thinking also you might be able to take a spring compressor and compress the spring, push the button and turn the piston. But I would think that might be harder to do than taking it off.
ashtray
Oct 21, 2010 09:02 PM
Shanty
Jul 28, 2010 11:34 AM
Confusion
Oct 20, 2009 03:23 AM
want sc300
Nov 10, 2007 04:26 PM
tmex05
Jul 3, 2007 07:57 PM
