usdm 550cc injector into 1jz
Old Jun 5, 2008 | 08:01 PM
shonuff53's Avatar
shonuff53
Default usdm 550cc injector into 1jz
ran into an issue for not looking into things like i normally do. installing the usdm 550cc injectors into my 1jz using a resistor pack, I did not even bother checking to see if my injector clips would plug in since I figured they would. Now im in a corner and need some help so does anyone know if the stock ge injector clips will plug in or if some other injector clips would work that can be purchased asap. I need to do this by tomm and I dont know if the dealer will have them in stock. please help, and thanks if you do.... Gabe.
Old Jun 5, 2008 | 09:43 PM
shonuff53's Avatar
shonuff53
c'mon someone knows, I really need this info.
Old Jun 6, 2008 | 03:19 AM
5spdSC300's Avatar
5spdSC300
Your going to need GTE injector clips. The 1j is slightly diffrent, same as aristo which is a common upgrade. Check the supraforums, im sure you can pick them up fairly cheap. Create a thread in the WTB section.
2jzinsider
Sep 25, 2012 09:05 PM
got-sc?
Feb 24, 2010 04:10 PM
BigGreen
SC400 / 300 Classifieds
May 8, 2009 09:49 AM
kaotiq
May 17, 2005 08:50 AM
