Airbag fuse??
Old May 30, 2008 | 09:32 AM
Billy305's Avatar
Billy305
Default Airbag fuse??
I want to put my soarer wheel that I bought on ebay and I searched and found the process to do this. What I found told me to pull the airbag fuse so it doesn't discharge... where is the fuse because I cant find it and I really dont want to have to pull the ground off my battery and lose all my settings. Thanks!
Old May 30, 2008 | 10:26 AM
5sp_jzz30's Avatar
5sp_jzz30
there is no ground for the airbag system. you dont need to disconnect the battery either. just replace the wheel. after you are doe you will most likely get the airbag light but you can search on here how to reset it.
good luck
soarer wheel or soarer wheel with soarer center cover. some soarer centers never came with airbags.
Old May 30, 2008 | 07:00 PM
Billy305's Avatar
Billy305
good luck
Its a full wheel with the cover. I need to remove the entire wheel including the airbag to replace it. The wheels looks the same except for the cover, I was assuming I could use the airbag I have now in the soarer wheel. From what I read however you are supposed to disconnect the battery or the air bag could deploy while i'm messing with it. Can someone confirm? Thanks
Old May 31, 2008 | 05:06 PM
Billy305's Avatar
Billy305
Anyone? I want to do this tomorrow and don't want to get knocked out by my car. Thanks!
Old Jun 1, 2008 | 01:58 AM
5sp_jzz30's Avatar
5sp_jzz30
dude your not going to set off the air bag. seriously stop being a p*ssy. its not a big deal. either just do it with the battery terminal removed or with it on. i have changed bags on plenty of cars before using both ways and nothing has ever happened. i have personally pulled the wheel off of my sc about 5 or 6 times changing between stock wheels and different aftermarket ones. it doesnt do anything.
sorry about the p*ssy comment im kinda drunk. but seriously you will be fine.
Old Jun 1, 2008 | 12:55 PM
Billy305's Avatar
Billy305
lol don't worry about it. I'm not worried either, im just going off what I have researched elsewhere. And from what I heard the are expensive to replace. That being said ill post pics tonight. Thanks
jefferino
SC400 / 300 Classifieds
Jan 9, 2009 08:32 PM
RedPhoenix
Jul 21, 2008 10:37 AM
VJ RC51
Dec 14, 2005 10:21 AM
