92-95 Sc300/sc400 Obd1 Code Retrieval
Old May 6, 2008 | 07:40 PM
socal300's Avatar
socal300
Wink 92-95 Sc300/sc400 Obd1 Code Retrieval
Lexus Code Retrieval
Accessing Diagnostic Trouble Codes
The check engine warning light will come on when the ignition switch is turned On and the engine is not running. When the engine is started, the check engine warning light should go off. If light remains on, the self-diagnosis system has detected a fault in the system.
Battery voltage must be 11 volts or more. Throttle valve must be fully closed. Transmission must be in Neutral position. All accessories must be turned Off.
On pre-OBD II models, turn ignition to On, then use a jumper wire to connect terminals TE1 and El of the data link connector, located under the left hand side of the instrument panel. Codes are indicated by the number of flashes of the check engine warning light.
Reading Trouble Codes
If the ECU has detected a system malfunction, the check engine light will blink every .5 second. The first number of blinks will equal the first digit of a two digit diagnostic trouble code and after a 1.5 second pause, the second number of blinks will equal the second digit of same diagnostic trouble code. If there are two or more DTC's, there will be a 2.5 second pause between each. After all DTC's have been output there will be a 4.5 second pause and all DTC's will be repeated as long as the terminals TE1 and El of the data link connector are connected. In the event of two or more DTC's, indication will begin from smaller numbered code and continue in order to the larger. After all DTC have been recorded, remove jumper wire.
Clearing Trouble Codes
After service, the diagnostic trouble code or DTC's retained in the ECU memory must be cleared by remove the EFI fuse for approximately 10 seconds or more, depending on ambient temperature (the lower the temperature, the longer the fuse must be left out) with the ignition switch off. DTC clearing can also be done by removing the battery ground cable, other memory systems (clock) will also be cleared. If the diagnostic trouble code is not cleared, it will be retained by the ECU and appear along with a new DTC in future trouble codes. If it is necessary to work on engine components requiring removal of the battery ground cable, confirm no DTC's are stored. After clearing codes, road test the vehicle to check that a normal operation. If the same diagnostic trouble code appears, the trouble has not been corrected.
OBD1 codes:
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
Electronically Controlled Transmission Control Signal
17
CMP No. 1
18
CMP No. 2
21
Main O2S & Heater Signal
22
ECT Sensor Signal
24
IAT Sensor Signal
25
Air–Fuel Ratio Lean Malfunction
26
Air–Fuel Ratio Rich Malfunction
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
Air Flow Meter Signal
35
HAC/Barometric Pressure Sensor Signal
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
Secondary Injection System Malfunction
51
Switch Condition Signal
52
KS Signal
53
Knock Control Signal
55
KS Signal
70
EGR System Malfunction
71
78
Fuel Pump Control
www.sosupholstery.com
Old Feb 10, 2011 | 04:12 PM
brad11140's Avatar
brad11140
Subscribed for reference
Old Feb 10, 2012 | 04:13 PM
WadeLovell's Avatar
WadeLovell
Also subscribed for reference.
Old Jul 7, 2012 | 11:26 AM
want sc300's Avatar
want sc300
I'm having a few problems with the diagnosis here,
prob just going to call me a idiot now but, i can seem to locate the 3rd 02 sensor
i am running three codes 21,27,28
21,28 are the mains and 27 is the sub signal where is this sub signal located i ran the entire exhaust form the cat back and i can't find it???
Old Jul 7, 2012 | 11:28 AM
want sc300's Avatar
want sc300
ok so now I'm seeing that some years ago a few people ran into this problem, something with the ECU coolant sensor is bad. i don't have a spare ecu to test this theory.
aceboogie6
GS - 1st Gen (1993-1997)
Feb 13, 2011 10:28 PM
acc
Jun 10, 2010 09:49 PM
socal300
May 6, 2008 08:13 PM
JHolmesSC4
Jun 10, 2007 04:06 PM
GOLDSc300
Maintenance
Apr 15, 2007 07:32 AM
