check engine light PO 125
Old Mar 13, 2008 | 06:03 PM
mcslexus's Avatar
mcslexus
Default check engine light PO 125
My check engine light is on in my 99 sc with P0125 as the only code, does anybody know what I should check first, maybe O2 sensors?
Old Mar 13, 2008 | 06:06 PM
RexNICO's Avatar
RexNICO
Here's what I go from a quick search
Indicates the ECT or CHT sensor has not achieved the required temperature level to enter closed loop operating conditions within a specified amount of time after starting the engine.
possible causes:
Insufficient warm up time
Low engine coolant level
Leaking or stuck open thermostat
Malfunctioning ECT sensor
Malfunctioning CHT sensor
checked alldata and according to that it points to your front oxygen sensor. I'm more inclined to go by this than my previous post.
code desciption points you in the wrong direction ....... O2 is the cause, and was damaged by coolant when the head gasket failed.
Old Mar 13, 2008 | 06:08 PM
Dx3's Avatar
Dx3
Insufficient Coolant Temperature For Closed Loop Fuel Control
Jonny
Lveyolfe
May 14, 2014 09:55 PM
atlantis43
RX - 1st Gen (1999-2003)
Sep 19, 2010 11:13 AM
clevercat
Jul 7, 2009 06:39 AM
howiedoit
Jan 30, 2002 01:08 PM
