electric turbo!:)
Old Mar 4, 2008 | 01:56 PM
  #31
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Originally Posted by CCC-TT
well lately ive been thinking about a gerbal powered turbo/ supercharger. Just get one of those wheel things they run in at the pet store and wrap a belt around it to a fan and stuff a gerbal inside... BOOM! extra 30rwhp. Trust me guys.
What type of gerbil are you running? my guinea pig just crapped out on me the other day.
Old Mar 4, 2008 | 07:26 PM
  #32
DIrEctQL's Avatar
DIrEctQL
Chicago Lexus Club Moderator
http://www.youtube.com/watch?v=9uN6Aahycf0
Old Mar 4, 2008 | 07:51 PM
  #33
100mgbluep's Avatar
100mgbluep
I believe the west african cotton tail would be used in his scenario. I hear they can produce up to 50 ponies and run for days on end!
P.S. E-turbo/charger = fail.
Old Mar 4, 2008 | 09:54 PM
  #34
3000's Avatar
3000
Just keep feeding it, so it won't die on you.
Old Mar 5, 2008 | 10:38 AM
  #35
TLDriver's Avatar
TLDriver
The biggest problem about these are the amp's that are required for a decent motor. Not only will you need to get a bigger battery but probably a second one and bigger alternator. So will the weight to extra power gain (if any) might not be worth it. A compressor spinning at 50,000 RPM is about 6-9lbs to get the compressor spinning you will need some torque on the electric motor, and to get it to spin up 50k rpms you will need some how to gear it to spin up to that rpm. Sounds doable but with a lot of factors. Something that I have never looked into would be adding some type of compressor to each air intake slot. It would require less from the motor and compressor if you are going to be using multiple compressors. This should also require less torque and rpms from the motors to make the same about of boost, but more weight once again and also a lot of custom piping, TB's, and the list goes on. Remember guys the ideas that were most laughed when brought up are usually laughed because it's not understand or by people who hate change. I love new ideas! But like anything new there are a lot of bugs to work out.
Old Aug 21, 2009 | 10:04 AM
  #36
SCLexxxy's Avatar
SCLexxxy
Originally Posted by MERXUS
http://www.youtube.com/watch?v=lj3iN...eature=related
she might shed some light on eturbo
Wow...if she says such as again im gonna flip.. LOL she is a certified retard... Bet she's good in bed tho
Old Aug 21, 2009 | 10:16 AM
  #37
forcefed86's Avatar
forcefed86
Just a little something for all the electric turbo non-believers! It's real and it works....
http://www.popularmechanics.com/auto...71.html?page=3
Old Aug 21, 2009 | 04:04 PM
  #38
2jzlex's Avatar
2jzlex
Pretty epic post there. Unless I missed the page, or you posted the wrong link, it mentions absolutley nothing about "electric turbos"...... it mentions electronic controlling of various valves within the compressor and turbine housing to decrease lag. But uh.... nothing about electric motors to actually produce positive pressure....
Old Aug 21, 2009 | 05:15 PM
  #39
forcefed86's Avatar
forcefed86
Actually it does.... electronically assisted. As In it pre-spools the turbo to eliminate lag. So while it's not solely an electric turbo per-say... It is a functional electric motor built into the compressor of a standard turbo.
Garrett has also developed an electrically assisted turbocharger that doesn't rely solely on exhaust gas flow energy. At low engine speeds, an electronically controlled electric motor responds to engine load and boosts the turbo up to high-pressure speeds. At high engine speeds that produce enough exhaust flow to spin the turbo's turbine, the overrunning motor can be used as a supplementary generator for the vehicle's electrical system.
Old Aug 21, 2009 | 06:39 PM
  #40
BoostLogic's Avatar
BoostLogic
Originally Posted by turbodremz
sounds like me and my drunk thoughts of putting a t25 on my SC3
Are you for real? That's awwwwsomelolollollololololllollol......
Old Aug 21, 2009 | 08:40 PM
  #41
2jzlex's Avatar
2jzlex
Huh, must have missed that.
Old Aug 21, 2009 | 10:08 PM
  #42
QwkSC's Avatar
QwkSC
Just stick a leaf blower in the intake: 10% more power
http://videos.streetfire.net/video/L...-Dyno_7514.htm
Old Aug 21, 2009 | 10:14 PM
  #43
madmax98's Avatar
madmax98
Originally Posted by 5sp_jzz30
same here...
so how do you manage to double your torque at low rpm. thats better then any turbo i have ever seen. im getting 2 of those. no im gonna make a custom ITB setup with a blower per cylinder. then change my license plate to "e trbo mn"
Let n = number of fans, and != infinity, then LIM ( HP )n->! = 100 hp
Old Aug 21, 2009 | 10:18 PM
  #44
madmax98's Avatar
madmax98
Another thing; Why is this forum getting more moronic by the day! I think our cars became a learning platform for every Tom ***** and harry............
Old Aug 21, 2009 | 10:28 PM
  #45
QwkSC's Avatar
QwkSC
Stop the copy?
