SC 400 Windows don't work
Old Feb 24, 2008 | 08:58 AM
stingone13's Avatar
stingone13
Default SC 400 Windows don't work
need hep with 1992 400 sc. windows stopped working, checked fuses and nada, how to check switches? how to check regulators if in working order.
Old Feb 24, 2008 | 02:08 PM
EpixINC's Avatar
EpixINC
is it just one side that doesnt work? which side? both windows? give us a little more info and we can help u
Old Feb 24, 2008 | 02:59 PM
Curry's Avatar
Curry
CL Folding 25,000
Yea more info.
Check to make sure the master switch is properly plugged in. If not its probably your regulators.
Old Feb 24, 2008 | 09:18 PM
schwarz's Avatar
schwarz
See if your passenger side window goes down with the PS switch...if it does but not with the DS control, I think you've found the culprit (and if you've driven with the window down while using the wipers, water dripping in will quickly kill the master switches).
Old Feb 24, 2008 | 10:16 PM
EpixINC's Avatar
EpixINC
or it could be something as simple as the little blue wire in the door hinge got broke... then u put a piece of wire in between and VOILA! problem fixed... if it works from the PS then its most likely that one wire pulled
Old Feb 24, 2008 | 10:18 PM
Ruri's Avatar
Ruri
I have the same problem, I think its the wiring harness on the door. The wires have become brittle over the years and broke a part.
Old Feb 25, 2008 | 09:24 AM
Turbo?'s Avatar
Turbo?
check the seals, at the end of the door, where your door opens.. water may have seeped threw and created humidity. witch then broke the wires...
toysGS
Sep 13, 2022 05:44 PM
AC1984
Sep 1, 2012 03:52 PM
stonewis
Nov 7, 2006 12:47 PM
gundaman
Sep 26, 2005 02:35 PM
gundaman
Aug 18, 2005 10:07 PM
