Does my Head need a rebuild?
Old Jan 11, 2008 | 10:02 PM
Levistey0's Avatar
Levistey0
Exclamation Does my Head need a rebuild?
My car overheated the other day due to low coolant (I know ::hammer:: ) My friend bought some Coolant to try to fill up the radiator. The Radiator ended having a leak. I got the car towed home and tried to refill the radiator again and found out the radiator was leaking all over.
My friend let me have his extra radiator and I replaced my old one. I put some new fluid in then started the car. The car started but it sounded horrible. It sounded like it was an really un-tuned Carb'd car. It turned the car off to find out what it could've been. I couldn't figure it out so I tried starting the car again and it wouldn't. The car would crank but it wouldn't turn over.
a friend of mine checked the car, he topped off the radiator and told me to start the car. A bunch of water came out of the top. He told me the head is F'd!
It's going to run about $1200 to rebuild the head. I just want to know if it's the head for sure that I have to replace or rebuild.
Old Jan 12, 2008 | 04:57 PM
aliga's Avatar
aliga
Former Sponsor
1200 for the head, it will be cheaper to change the motor.
do you have a sc3 or sc4?? i have a few motors, that i can ship if you want to go that route
Old Jan 12, 2008 | 07:06 PM
Bean's Avatar
Bean
CL Folding 1,000,000
Dont rebuild the head... just pick up a used one and have it cleaned up and checked at your local machine shop (NAPA did both of mine). Cost me $150 which included the cleaning of the valves, cleaning of the entire head and crack/warpage checking. You can find used heads for cheap and they can come from any OBD1 car.
Its some work, but it isnt $1200 , more like $350 including the cost of the used head and other parts
Old Jan 12, 2008 | 09:43 PM
halizm's Avatar
halizm
Way cheaper to buy another ge engine. 1200 you almost got you a tt motor. LOL
Old Jan 13, 2008 | 11:56 AM
crx378's Avatar
crx378
get a used head for sure. so you have a ge or gte? sorry didnt see your specs i can get you one shipped as well if needed.
Old Jan 14, 2008 | 08:38 PM
Levistey0's Avatar
Levistey0
Sorry for not specifying earlier.
It's a 300 with a 2JZ-GE
Wow, thanks for lookin' out guys, i was ready to drop that money. I just need her going again. ASAP.
I'll post a WTB ad on the classified. unless someone has one lying around!
It's Good to see there's honest people still out there!
Old Jan 14, 2008 | 09:03 PM
qksl2's Avatar
qksl2
Do a compression test, you don't even know your head is bad. Just because it won't start doesn't mean the head is bad.
Ian
Old Jan 18, 2008 | 07:24 PM
Levistey0's Avatar
Levistey0
I'm trying to find out why it doesn't start. You have to be able to turn it on to run the compression test.
The motor has about 200k on it, so replacing the head would've been in the future plans anyways.
Old Jan 18, 2008 | 08:36 PM
Rey's Avatar
Rey
As long as you can crank the motor, you can check compression.
Old Jan 18, 2008 | 09:36 PM
Bean's Avatar
Bean
Check on supraforums too; there's plenty of GE heads out there for good prices
ISsparta
IS - 1st Gen (2001-2005)
Feb 8, 2023 02:38 PM
Avalos300
Aug 31, 2017 07:37 PM
SupraDremr
Aug 14, 2012 02:51 PM
huerdo623
Aug 26, 2007 12:56 PM
toykilla
Maintenance
14
May 28, 2006 12:27 PM
