Ignition or Accessory Wire for SC400..Help!
Old Dec 25, 2007 | 02:39 PM
KC95SC400's Avatar
KC95SC400
Originally Posted by stevechumo
Thanks KC,
It could be the problem with my batttery as well. But there's 1 thing that I think would be the difference between this hydro pump solenoid and the regular electric fan is this hydro fan always runs by the belt. I think that solenoid is more like a hydro pump sensor that allows more oil to go to pump to cool it down. It's not like a direct coolant sensor that works with the electric fans. If you can , please post your wiring diagram.
Possibly. My take - The pump is alway belt driven but the solenoid controls how much fluid is allowed to move to the actual hydro fan. If I'm not mistaken, the hydro fan always turns a little, but the solenoid allows fluid to bypass or sends more to the pump based on the cooling needs of the engine.
I will try and post the hydro pump outline and a wiring diagram tomorrow for you. If I can't post them, I'll PM you for your email.
KC
Old Dec 26, 2007 | 05:58 AM
KC95SC400's Avatar
KC95SC400
Here's some good info for you.
KC
EDIT: I have the full RM doc for testing and removal, but it's too large to upload. If anyone who plans to remve the hydro pump needs it, PM me with your email.
File Type: pdf
Old Dec 26, 2007 | 06:55 PM
stevechumo's Avatar
stevechumo
KC,
You have an excellent diagram. I have a similar diagram like yours (but no explanation) and I used the light blue to the solenoid and it didn't power enough the fans. Did you run each fan to each side of the solenoid? Did you use any additional thermo sensor at all? What wire color that you used?
From what I understand, the solenoid can increase the voltage to power enough the pump according to the water temp. sensor. This solenoid is originally a switched variable power source.
Old Jan 2, 2008 | 06:16 PM
stevechumo's Avatar
stevechumo
Originally Posted by WICKED 1
ign. is black yellow at the main harness
Just out of the curiosity, I followed this blk/ylw wire from the main ignition box and it's actually the fuel injector wire EFI. Luckily, I didn't use it to run the fans.
adreano17
Dec 22, 2010 09:11 AM
graphX250
Jun 16, 2010 08:40 PM
User1321989
Jan 30, 2009 10:46 AM
Breakaway
Dec 27, 2004 06:30 PM
Lvangundy
Apr 24, 2003 03:33 PM
