Boost controller install
Old Nov 15, 2007 | 07:04 AM
ucfa4's Avatar
ucfa4
Default Boost controller install
Im sure this has been answer a million times bt i cantfind any info on it. Where do i install these vacuum lines. I know one has to go on the intercooler piping and the other two on the waste gate. I just dont know where to put them. One says to connect to wastegate actuator and the other says connect to a secondary port on wastegate actuator. Does our wastegate have a single or dual port actuator?
Old Nov 15, 2007 | 09:58 AM
jgdynamics's Avatar
jgdynamics
i asked this back then also, and i hooked mine up fine, but i totally forgot whut i did... i think i T'd the line off somewhere to split into both wastegate actuators.. FRONT AND REAR TURBO... took some elbow grease to get in there, and i beleive both lines from each actuator was T'd to my EBC solenoid... hope someone here can give u detailed info... it totally slips my mind on the install..
Old Nov 15, 2007 | 04:42 PM
ucfa4's Avatar
ucfa4
Damn I wish you still had it hooked up so i could see what you did. Thanks though.
thegadget
Jun 17, 2009 03:54 PM
Turbo?
Jul 27, 2008 09:29 AM
1JZ300
Nov 7, 2007 10:54 PM
