installation kit for walbro fuel pump gss341
Old Nov 9, 2007 | 10:03 AM
RX7 RAGE's Avatar
RX7 RAGE
Default installation kit for walbro fuel pump gss341
Is the installation kit necessary for an sc300 or do you guys use the stock wiring? Thanks.
Old Nov 9, 2007 | 10:09 AM
shlounek's Avatar
shlounek
yes use the original wires, your old plug might plug in, if it doesnt then use the supplied adapter "plug" that came with your pump, match the color of the wires splice solder and tape.
there is a whole write up on www.clubna-t.com or here, search is your friend.
Old Nov 9, 2007 | 10:29 AM
lemmiewink's Avatar
lemmiewink
I believe you mean shrink wrap instead of tape? At least with me I actually used the crimps supplied and electrical taped it at first. I went back to solder and looks like the tape just got unstuck and left the crimps exposed. I'm not electrical savvy but I'm guessin exposed wires in a gas tank is pretty scary
Old Nov 9, 2007 | 11:47 AM
shlounek's Avatar
shlounek
actually i am sorry dont use electric tape, your right the fumes will actually make the tape not stick anymore, and if you want to use heatshrink make sure you use a heat gun or something similar, i would suggest using a lighter near gas fumes.
I used the small electric plastic twist ons, i dont know what you call them, but basically what electricians use in electric conduits etc. I would believe that is your safest bet. good luck
Old Nov 9, 2007 | 11:51 AM
Gunnar's Avatar
Gunnar
Is it possible to get the filter and plug adapter separate? I got my pump off a friend who'd had an extra he never used, but all I have is the pump.
92lexi
Oct 18, 2014 04:55 PM
HiPSI
Oct 9, 2012 10:46 AM
shaodome
Dec 15, 2009 07:21 PM
onebadshot
Jun 26, 2006 08:01 PM
