Who has the wierdest SC problem?
Old Oct 9, 2007 | 03:26 PM
rykwebb's Avatar
rykwebb
good one sliva.
Old Oct 9, 2007 | 03:50 PM
joe diego's Avatar
joe diego
My ac smells like fat-chick swet
Old Oct 9, 2007 | 04:13 PM
NYCsc300's Avatar
NYCsc300
my pass side seat moved forward while i was in park. scared the B-jesus out of me. then the top part tilted forward and was doing that rocking motion till i got out and open the door..(it took like 5min before i open the door) it was around 10pm and i just dropped off my gurl.. still dont know what cause this.. nothing in the door jam or between the door or seat..
if my gurl was still in the car it might have crushed her legs... no body believes me.
i dont do drugs and work for the city...
Old Oct 9, 2007 | 04:28 PM
neurocity's Avatar
neurocity
Not quite my tempo
Originally Posted by rykwebb
The day I got my AC running my windows stopped working, plus my driver side air vent doesn't blow air at all.
Kick panel fuses, one is out of whack. Take the fuse out and bend the blades slightly in opposite directions of one another. Dvr-side vent not blowing could be a blocked or disconnected duct.
Originally Posted by acenase
My radio doesn't work
Check fuses and wires, then ebay a new one.
Originally Posted by MCG33
Sounds like you need some trunk sharks!
LOL!!!! I forgot about that thread.
my 'turning signal arm' wont click back after i turn, even if its full radius, no idea how to solve this.
Clean the switch, sounds like someone got a little too much armor-all or silicone shine jizz in there and all the fun dust has made a gummy mess.
Way tooo many things I could say....(Make sure your passengers are properly bathed.)
Finally....If you have a problem....Search. Chances are someone else has had the same problem.
Old Oct 9, 2007 | 05:06 PM
xx69xx's Avatar
xx69xx
My passenger widow gets stuck on the rubber lining thing so i have to go up and down.Takes about a min to bring the window down. I need A.C
Old Oct 9, 2007 | 05:08 PM
benxd's Avatar
benxd
CL Folding 25,000
Mine seems to be unable to park next to other cars. It has to park away from everyone else.
Old Oct 9, 2007 | 05:17 PM
neurocity's Avatar
neurocity
Not quite my tempo
75W-110 gearlube should do the trick.
Excuse me for one moment....
https://www.clublexus.com/forums/sho...t=Stuck+window
https://www.clublexus.com/forums/sho...indow+Sticking
oh and.....
Old Oct 9, 2007 | 05:34 PM
AutoCoutureSC's Avatar
AutoCoutureSC
My car is in the shop for 6 months out of the year...
Old Oct 9, 2007 | 05:39 PM
greyBLITZ's Avatar
greyBLITZ
Whenever my cell phone rings, I frantically try to turn down the volume and instead of the volume decreasing, it blares it momentarily and then turns down. On occasion, even after turning it to the very end, I will still hear sound.
Old Oct 9, 2007 | 05:51 PM
scENFORCER's Avatar
scENFORCER
I put out a post on my problem. Then it was moved to the 'suspension and breaks' section, and everyone stopped responding.
My breaks lock-up about 10 minutes into my ride (in the mornings), then I usually have to pull over for about 10 minutes and wait till they release. Then the car is fine for the rest of the day. Some ppl said pads (so I got new pads), some ppl said rotors (so I resurfaced my rotors), some even said its not the breaks, the transmission was just not pulling (transmission was checked and its fine). Problem still persists. Maybe a sensor? A fuse?
Heres the link to my post..
https://www.clublexus.com/forums/sho...d.php?t=307524
Once again, ANY help would be appreciated..
- Sammy
Old Oct 9, 2007 | 05:58 PM
F3DERAL's Avatar
F3DERAL
Sometimes when i press my brakes it makes this loud noise no idea what that is
Old Oct 9, 2007 | 06:24 PM
TheMole's Avatar
TheMole
- Sammy
Try flushing out the brake fluid and putting new fluid in. If that doesn't work a caliper maybe be starting to seize.
Old Oct 9, 2007 | 06:28 PM
tkafam1's Avatar
tkafam1
Originally Posted by sc250tt
I think all sc owners can vouch for their car being a gold digger .but hey she's hot so i dont mind spending money on her
When I am coasting at 24 mph (not accelerating) my car makes a strange clicking noise. 23 mph or less, nothing, 25 mph or more, nothing.
Old Oct 9, 2007 | 06:58 PM
rykwebb's Avatar
rykwebb
This thread was not an attempt to pi$$ off the moderators, we definitely dont want that, just to see who has the most out of whack wierdest problem they just cant seem to fix. Searching is the first thing everyone should do.
Like tkafam1, that is just wierd man...
Old Oct 9, 2007 | 07:09 PM
CStrikeSC's Avatar
CStrikeSC
My interior lights dont work(except for climate control, guage cluster, and radio), keyless entry doesnt work, tilt steering wheel doesnt work, and my trip odometer resets everytime i shut off the car. Any clues?
BTW, all fuses are good.
