water soaked engine
Old Sep 26, 2007 | 12:24 PM
thebadz32's Avatar
thebadz32
Default water soaked engine
so i decided to detail the engine bay for a car show comin up this weekend and now its hardly running, I checked the distributer cap for moisture didnt find any pulled the wires no moisture checked the ignition modual no moisture the mass air flow is dry and so is the conector is there somethin im missing?? neld to get this figured out asap.
Thanks
Old Sep 26, 2007 | 05:09 PM
Fireblaze's Avatar
Fireblaze
Many posts on this. Here is mine to be exact (with pictures)
https://www.clublexus.com/forums/sho...d.php?t=281628
Old Sep 26, 2007 | 05:10 PM
99SC42's Avatar
99SC42
try blowing some air in the spark plugs area dont remove the plugs until u blow the water out i had the same problem remember dont drive the car or u gonna mess up the converter .
Old Sep 30, 2007 | 08:56 AM
pinto096's Avatar
pinto096
mkan just went through water up to the doors finally got it running right if water got sucked into the intake you have to remove it andclean it all just speaaying into the intake with throttle body cleaner just wont do, also dry gas into the tank just in case, and look at all fluids including radiator, as well as water in the oil drain 2, also i do recommend removing all 6 plugs if it is an sc 3oo and turn over motor to clear out water, and try tolift the front end to get most of the water in the mufflers out, i dont know how much water you got into the car this is recommended for the extreme flooding
Old Sep 30, 2007 | 09:16 AM
evileagle's Avatar
evileagle
describe hardly running, what is it doing.
Old Oct 1, 2007 | 08:17 AM
suprana96's Avatar
suprana96
I had this problem a couple times with my Supra. It gets water in the spark plug holes. only thing that can be done is let it dry. remove the spark plugs dry them and let the water drain. Depends how much water you got down there. The ge stinks for that because of the intake plenum that goes over the engine. the gte has the whole spark plug section covered.
AnthonyMtz
RX - 1st Gen (1999-2003)
20
Sep 3, 2020 07:49 PM
aviator101
Mar 21, 2018 06:27 AM
buggsc3
Automotive Care & Detailing
15
Apr 27, 2005 09:16 PM
jdmdaddy
GS - 1st Gen (1993-1997)
31
Feb 16, 2005 09:02 PM
TMaxxTim
Oct 14, 2004 09:04 PM
