Hello all, i'm about to do a 2JZGTE sc300 swap... Before I get started I want to gather as much information as possible. I have tried searching but can't seem to come up with anything. If some of you, could post up any and all information about the swap, it'd be greatly appreciated.
I'm also looking for a detailed list of parts that are needed in order to complete the swap!
Jim
Jim
Do a Search, I did the 2jzgte into the 400 but SC300TT did it in an sc300. I think that was his screen name got good details. Also, go to MKIV.com and you will find the wire diagram for the usdm 2jzgte which is only a little different from the sc300.
I know you will need these for sure:
-TT Throttle Cable
-SC300 Baffle
-SC300 Oil Stainer
-SC300 Upper Oil Pan
-SC300 Oil Level Sensor
-SC300 Lower Oil Pan
-SC300 Dipstick
-Heat Shrink
-Roll of Wire
That is all I can think of at the moment but there is a lot more.
-TT Throttle Cable
-SC300 Baffle
-SC300 Oil Stainer
-SC300 Dipstick
-Heat Shrink
-Roll of Wire
Quote:
Can you post a more direct link to that diagram? I am currently looking for ANY wiring help I can get. The wiring sucks! Mine is a 1jz, I hope the wiring isn't that much different.Originally Posted by SimplyZBes
http://mkiv.com/manual/manualtt/term...ecm/index.html
http://mkiv.com/manual/1995_electric...ual/index.html
http://www.jzgte.com/tech/1jzgte/1JZ...iring.v1.1.pdf
If anyone has more to add - I will be in your debt. Thanks
1UZFE/2JZGTE
Quote:
Assuming you got a soarer harness your wiring will simply consist of extending the body plugs.Originally Posted by ProjectLex
Jim
Here's some of my trials and tribulations with this swap. Mine is a 1jzgte, but the info should be pertinent.Originally Posted by Sngledsupe
Hello all, i'm about to do a 2JZGTE sc300 swap... Before I get started I want to gather as much information as possible. I have tried searching but can't seem to come up with anything. If some of you, could post up any and all information about the swap, it'd be greatly appreciated.I'm also looking for a detailed list of parts that are needed in order to complete the swap!
Jim
https://www.clublexus.com/forums/sho...d.php?t=285515
Good luck and keep us updated!
You know if you keep helping them, they dont go away. The info is out there. People just dont seem to understand not everything is located in ONE thread.
Wasnt there a guy here like just yesterday that asked the SAME EXACT QUESTION?
