Weird things happening
Last night, Well I was driving on the highway crusing at like 75mph and all of a sudden every electrical thing shut off and I thought the car died. I pulled over to the side of the road and 3 seconds later everything turns back on and my car was still idling for some odd reason. I drive it home and then I opened the hood and checked everything and it looked fine. I go to check the batter terminals and i go to remove the cover for the positive and the whole cable came off with it. I reattached it and started the car and it started then died. Tried it again and same thing. I go tighten all the terminals and do it again and same *****. So i try it again and this time I kept the idle up and I let off and it slowly dropped and died. I do it again and held it for some time and it was holding idle rock solid. I turned it off and checked it a few times and it was good. I go to check if it was my battery or alternator so I started the car pull the positive terminal off and the car was still on. So I think its my battery. I left the terminals off and I went inside.
Today, I go reattach the battery terminals and started the car up and it went to like 1k and dropped and died. I tried holding the idle up again and I let of and it died again. I hold it for a long time and it slowly drops and barely still running and very low rpms then dies. So I decided to keep the AC on and it idles fine. Then it was warming up and I tried it again and the warmer it gets the higher it idles and it even idled without the ac on. The weird thing is the car beeps every time when I start the car now like how you reset it and it beeps and now it does that everytime.
So what is wrong with my car? I don't think its the battery or the alternator. What caused everything to shut off on the highway? Did somehow it fried my idle air controller? I checked the fuses it looks fine. Which fuse controls idle? Why does it keep beeping now?
Ok, I guess I figured out the beep. I had the phone in back in the day and it was off and i removed it which = beep free.
I guess since the car was reseted the beep is here.... and I don't want to install the phone to turn it off lol.....
Still don't know what else is causing the other stuff.
Here is the fix for the car phone beep: https://www.clublexus.com/forums/sho...d.php?t=286836
As for the other stuff, I don't know.
topgun129
Aug 24, 2014 05:10 PM
Awol Mikey
Jul 5, 2010 06:17 PM
