Help, Swap Soarer Stuck, Help.
MY SWAP GOT ON HOLD. ENGINE MOUNT BROKE ON 2 JZ AND 1JZ, ALSO NOBODY CAN CONFIRM THE DRIVE SHAFT ISSUE. COME ON, SOMEONE USED SOARER 1JZ WITH R54 BEFORE.. I HAVE NO DRIVE SHAFT AT ALL. DOES IT SOUND RIGHT , REAR SC300 SHAFT WITH MK3 SUPRA FRONT-WHAT YRS SUPRA WORK? NEED TO ORDER ASAP................
The mounts - the same thing happened to me, this is what I did, cost me 4 dollars.
https://www.clublexus.com/forums/sho...tom+puck+setup
maybe not necessary, but if the only thing standing between me driving my car with the new motor was this issue, and the alternative was to order something that could take a few days to show up... I'd be at the driveshaft shop...
otodemicks
Sep 13, 2008 12:37 AM
