Replacing passenger side high beam
Old May 11, 2007 | 03:36 PM
99sc30077's Avatar
99sc30077
Default Replacing passenger side high beam
How do I remove my bumper to replace the high beam assembly on my 99 sc300? I was told this needed done in order to replace the glass that is broken over the top of the high beam.
Also, do I need a replacement from years 97-00? I also read that 92-96 won't work in a 99?
Thanks
Old May 11, 2007 | 04:41 PM
aliga's Avatar
aliga
Former Sponsor
i have a glass highbeam for sale, 50 shipped.
to take otu the bumepr, you need to pull the headlights, out, remove the rubber peice on top of the bumper, take out 5-6 screws on top, remove the plastic guards on the bottom, and the sides.
pretty simple to do, but time consuming.
Old May 12, 2007 | 08:14 AM
99sc30077's Avatar
99sc30077
Do you have the glass only or the entire assembly? What year is it from and is it the passenger side?
I take it the headlights are too hard to take off either? After I remove the screws the rubber piece and the plastic sides, it should come right off? I do have to do this to get to the high beams, right?
Old May 13, 2007 | 06:49 AM
aliga's Avatar
aliga
Former Sponsor
i have the entire highbeam from a 99, glass.
as for the lights, the toughest nuts to get to, are the ones by the inner fender lining. once you get those two out, and the upper bolt, it will pop out.
megamax
Jan 7, 2012 04:16 PM
Kira X
Sep 25, 2009 03:08 PM
swittie
Jan 28, 2009 12:46 AM
hknubsauce
SC400 / 300 Classifieds
Oct 2, 2007 09:02 PM
