US Spec 2JZ-GTE?
Old May 3, 2007 | 08:21 AM
TTSC3's Avatar
TTSC3
Default US Spec 2JZ-GTE?
I googled and searched like crazy for this answer, but I'm trying to figure out which motor I've got in my car. I was told that I had gotten a JDM motor, and have read about the differences between the two engines, but am unable to verify which one I got. The motor is already in the car and running, so I can't identify which turbos are on the car (steel or ceramic). The one thing I did notice was that my car has an injector resistor pack. It wasn't added to the car either, as it's definitely part of the factory harness. I was told that the JDM TT engine, does NOT have one, but that the US spec does. (High imp vs Low imp). Is this a for sure way to tell if I have a US spec engine? Is there any other obvious way to figure this out? Thanks.
Old May 3, 2007 | 08:49 AM
hemogoblin's Avatar
hemogoblin
Injector resistor box means 550 injectors. 550 injectors are from a USDM motor. If you say the resistor box is part of the harness, then it means you probably have a usdm harness. You probably have a JDM motor, with USDM parts.
Old May 3, 2007 | 07:45 PM
VGnomore's Avatar
VGnomore
look at your throttle body if it says trac control its usdm if it says "TRC" really big its Jdm
Old May 3, 2007 | 09:22 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
My money's on hemogoblin's theory. Most swaps go like he said.
Old May 5, 2007 | 01:35 PM
TTSC3's Avatar
TTSC3
Well, my TB says trac control, not TRC, so I guess I can safely assume it's US spec, but damn, I'd hate to turn the boost up and fry my turbos! I thought that most swapped cars were the JDM 2J's, not US spec, so I had figured I was part of the majority, not minority. Oh well, I guess I'll find out when I crank it up!
Old May 5, 2007 | 04:14 PM
96sc300tt's Avatar
96sc300tt
i was told that usdm actually was better than jdm for supras? idono but if thats the case youre a luck fellow.
MDSC
Jul 20, 2012 10:10 PM
Mr.Gs_GTE
GS - 1st Gen (1993-1997)
Apr 24, 2011 01:09 PM
thaimonkee
Nov 3, 2007 08:06 PM
BigManne
Jul 16, 2005 03:00 PM
