SC400 Headlight Issues......Help
Old Apr 18, 2007 | 11:34 PM
SRTibbitts's Avatar
SRTibbitts
Default SC400 Headlight Issues......Help
I'm having issues wiith my headlights. I've become pretty good at tearing them apart, cleaning and sealing them back up......about 6pair now. The problem I have is right now my passenger headlight is about 1/2 as bright as the drivers side.
Anyone have any ideas?
Thanks
Old Apr 19, 2007 | 12:19 AM
rkyat's Avatar
rkyat
i actually had the same problem when i first bought my sc. Bulbs worked fine, but passenger side was alot dimmer than driver. Didnt think much of it, so i installed an HID kit. both sides work good now. However passenger side still comes on and off every now and then. and i tested both the ballasts and bulbs. Thinking maybe the harness needs to be changed?
Old Apr 20, 2007 | 05:00 PM
2JZ_SC's Avatar
2JZ_SC
Check your path to ground on the pass head light. High resistance on a gound path is a normal cause for this prolbem. Corroded or loose ground point can cause this some times. Hope this helps.
Old Apr 20, 2007 | 11:29 PM
SRTibbitts's Avatar
SRTibbitts
Rockin!
I'll try that and see how it goes.
Thanks!!!
Robbie2j
GS - 1st Gen (1993-1997)
Apr 1, 2018 05:09 PM
Ogloc61
Apr 1, 2018 04:59 PM
Lilflip#2
Mar 10, 2009 08:44 PM
LuckySeven
Oct 19, 2006 07:24 PM
